When I play back MPEG-1 files via MediaPlayer 7.1, about
1 in 5 or so frames are dropped, and this makes the motion
non-smooth at times (I verified this by adding frame
numbers to each frame with VirtualDub, then playing
back via the TV-Out into a VCR, recording, then stepping
through the videotape). I downloaded the Cinematograph
video player and have the same problem. Can someone
suggest a good MPEG player that doesn't drop frames?
My system in 1400 MHz Athlon, 266 FSB, 7200 RPM disks,
Matrox G450 Dual Head video card. I am able to play DVDs
smoothly with the Matrox software (so hardware limits are
probably not the problem).
Results 1 to 1 of 1
Dropping frames on New PC
By beammeup in forum Capturing and VCRReplies: 9Last Post: 16th Apr 2012, 11:36 -
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 21:15 -
Dropping frames while converting to .dv
By Huntr777 in forum MacReplies: 1Last Post: 10th Jun 2009, 16:19 -
DivX Dropping Frames? But Why?
By Anakin in forum Video ConversionReplies: 5Last Post: 12th Apr 2009, 01:25 -
New Computer Dropping Frames
By bthig in forum Capturing and VCRReplies: 20Last Post: 14th Jul 2008, 15:06
