Hi All, I have been making svcd discs with titles etc for the last 3 years and now I have aquired a lite on 411s writer. After trying many different discs created using dvdshrink 3.1 and nero 6.2 to burn I found only one type to play perfectly in my pioneer DV-343 standalone player. This was a packard bell DVD+RW as I found all the DVD-R discs didn't work (some didn't even burn to completion). I did seem to find on the various forums that pioneer DV-343 players prefered DVD+R discs as oppesed to DVD-R ones, but after trying some mirror DVD+R branded discs I still got no joy.
So Are DVD+RW discs more suitable in this pioneer player or is it the writer that is being too picky with the type of media it uses. I Have read that 411's manufactured OCT 2003 were a bit flakey with the media they accepted, and after making over 150 SVCD's I'm finding a tough decision to break away from tried and trusted CDr to the newer DVD technology as I read of so many problems people have with media etc.
If someone can help shed some light on possible causes I would be greatfull.
Chears Tbone
For the DVD+Rs that you've been trying to play, are there dvd compliant files burned to it? Do these disks play in your computers DVD-ROM drive?
or
Are you triying to put one or multiple SVCDs onto DVD+Rs? What methods are you using if that it is the case? -
There's a firmware available for the Liteon 411 that will enable bitsetting capabilities on DVD+R/RW. Bitsetting increases the compatibility of DVD+R/RW discs.
You can download the firmware here: http://www.cdfreaks.com/news/9029
Help with svcd 2 dvd
By tastybaker in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 11th Aug 2010, 10:30 -
Svcd 2 dvd
By GeordieDave in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2010, 11:05 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
Can a SVCD video file be burned on to a DVD and played in a DVD player?
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 17th Apr 2008, 21:44 -
How to burn a SVCD onto a DVD?
By php111 in forum Authoring (VCD/SVCD)Replies: 9Last Post: 16th Oct 2007, 03:32
