Please help me?? I have downloaded a movie file and it saved as WinRar, so i have extracted it expecting an SVCD file (As that was in the name) but it is a BIN file and i am stuck on what to do, how do i play it or put it on disc?!?!?
Am i being really dumb, or no? Any ideas? Please?![]()
Results 1 to 16 of 16
"Your face can take a lot of punishment. That's good to know"
CUE or ISO are the only image files I've seen. Maybe BIN is a normal file but if I were you I'd wait and get more information before opening it. .BIN is the extension for a binary file and it could be anything.
try opening it with videolan. If it works ok, then burn the cue file with nero or whatever burning program you use.
If there is no cue file in your RAR archive to go with that BIN, you could probably still burn the image in Nero.
You could mount the BIN in Daemon Tools and do a CD to CD copy.
You could extract the video data with IsoBuster and recreate an image with VCDGear. VCDGear should also handle the RAR archive, and be able to extract the MPEG data.
Is there no ".cue" file with the ".bin" file? -
Best just to delete it and look for another 8)
j/k
makntraksIn the theater of the mind...
It's always good to know where the exits are... -
that is what they make antivirus programs and firewalls for. Assuming you are as anal about updated virus definitions and updating your programs as I am, then there is not a problem.
Wow, bit confused now lots to think about!! Thanks to all for the info though. I'll be back if i get stuck!
Ta.V.Much
"Your face can take a lot of punishment. That's good to know" -
Looking at it again, when i extracted from WinRAR, there is a .BIN, .sfv & burnatonce ???
Just use ISObuster and rip the mpeg from the bin. Worry about getting it on disc later. Once you have your mpeg you'll need to determine what kind of mpeg it is(SVCD or VCD). See this thread for more info: https://www.videohelp.com/forum/viewtopic.php?p=894646#894646
Don't mind the flaming though..Read more about SVCD and VCD specs by clicking on "What is VCD" and "What Is SVCD" in the upper left of this page. Also, you didn't mention what kind of disc you plan on putting the mpeg on. DVD or CD? DVD will require a lot more work on your part, just so you know.
if there is no cue file then there are freeware programs (do a search) that can be used to recreate a cue file, as this is the correct way to burn/mount a bin file, ive ran into problems just using the bin file to burn.
Originally Posted by teegee420"Your face can take a lot of punishment. That's good to know"
One suggestion that I always make:
If the movie is available cmmercially (ie. you can buy it), then you should purchase it and avoid any issues such as this. You also get better quality than SVCD, plus (possibly) extras. If it's available, you'll find that the cost of the DVD is less than the cost of the time it takes to screw around trying to convert or burn. -
Previous versions of CDMage use to make a cue file from a CD-Image.
http://cdmage.cjb.net/
It doesn't seem to work anymore. (for me) -
Originally Posted by Lozbug
For AVG users (missing bin file)
By stiltman in forum ComputerReplies: 6Last Post: 17th Aug 2008, 23:16 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 11:58 -
Opening .bin file jpg
By chewie8008 in forum ComputerReplies: 4Last Post: 18th Jul 2007, 16:01 -
Bin file
By anton225 in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 13:05 -
how to burn a BIN File
By Chris 67 in forum Newbie / General discussionsReplies: 4Last Post: 28th May 2007, 07:44
