Results 1 to 16 of 16
  1. First off I want to say this is my number one site. But there seem's to be some small problem's. One There is no forum link at the top of the page. I think this make a better lay out. The old font text was better and easier to read. Little bigger to see. When in a forum section or on the front page. I get yellow pop's of the topic that my mouse is on take's a while for it to go away. This might be a Java problem.
    Again want to say small thing that I do not like over the new lay out. But this is still my number one website on the net. Long live DVDRHELP!!!!!!!!!!!!!!!!!!!!!!
    I removed the popup javascript. It caused annoying problems, popups that got stucked now and then. I maybe will try find another javascript later.
    I'm not done with the main page design yet.
    But I will not have two forum links...both at the top and left.
    and it is www.VideoHelp.com
  3. Originally Posted by Baldrick
    This will take some getting used too....
    I for one had to change my links from vcdhelp.com to the new domain
    Originally Posted by jagabo
  4. Originally Posted by Baldrick
    well, can you move it back to the top of the page, please?
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    No.
    Aug 2002
    Behind the wheel of a R34
    I for one still use VCDHelp.com when I type it up....
    Next Generation Classic......
  7. Member Conquest10's Avatar
    Chicago, IL
    Me too.
    His name was MackemX
    I like videohelp.com better. Easier to say.
  9. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    I've been referring more and more people to the site recently, and videohelp sounds like a better place to send people than dvdrhelp. makes us less subversive and l33t though......
  10. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    I liked it better when this site was only about VCDs, and it was hosted on Geocities.
  11. Originally Posted by spiderman2k1
    If you're using Internet Explorer and don't like the font you can use whatever font you like by going to Tools, Internet Options, Accessability and selecting "Ignore font sizes..." and/or "Ignore font styles...". Then go back a step and set Fonts to whatever you want.
    Some sites don't render properly with those options set but this one does.
  12. Originally Posted by Baldrick
    No.
    thanks!
  13. Mod Neophyte redwudz's Avatar
    USA
    Baldrick, OK for me. I just want to play with the 'custom' option more, looks like fun.
  14. Guest
    Guest
    No.
    thanks!
    Ditto.Old habits die hard.
    Dec 2002
    My Swamp
    Also available in blue.
  16. Member vhelp's Avatar
    Mar 2001
    New York
    I have no complaints :P
    But, "vcdhelp" will always bring the nostalgic feelings of the gold old days of
    my first steps in VCD creations (March 2001) :P
    Cheers everyone,
    -vhelp
