I think that the term used is "rip" I have some small nero burned vcd clips which I need to put on another cd or if the worst comes to the worst a dvd. I was successful with svcd to dvd yesterday using vcdgear apart from a bit of flicker, so hopefully I can be equally with this venture. Which tools are recommended? How do rip them? Thanks Clive
Rip the mpegs from the VCD with ISObuster and cut/edit/join the clips as needed with TMPGEnc by going to File>MPEG Tools>Merge & Cut. Should you decide to put the clips on DVD there's no need to convert to DVD spec mpeg-2. VCD mpegs have a legal resolution. All you need to do is resample the audio to 48000hz. Certain authoring programs like TMPGEnc DVD Author and DVD Lab(I believe) can do this for you.
Auto DVD Rip - Put the disc in the tray and the program does the rest
By dw-wizard in forum DVD RippingReplies: 8Last Post: 16th Feb 2012, 23:54 -
Put mp3 audio file from hard disk to forrum post
By vitcon in forum ComputerReplies: 5Last Post: 18th Mar 2011, 11:11 -
How to put clips together in AVCHD/m2ts format?
By vpelton in forum Newbie / General discussionsReplies: 2Last Post: 17th Jan 2011, 08:31 -
is there a DV editor that can import all clips and put them in order?
By Onceler2 in forum EditingReplies: 0Last Post: 15th Oct 2010, 21:38 -
Can't put to work Advanced High Definition Disk Creator
By mahogany in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2010, 04:56
