I have a LG GSA-4040B combo drive which can read DVD-RAM disks. I originally installed it with version A301 firmware and it has worked fine. However last week I installed version A303 firmware (the installation appeared to be successful) but now I am unable to read DVD-RAM discs. When I try and access it I get the following message: "E: is not accessible. Access is denied". I have tried a number of different RAM discs but get the same message each time. Previously I had no problem in reading these discs. I am running XP Home SP1 and run under administrator so there should be no security issues.
Can anybody suggest a solution?
If it worked before, then I would go back to the old firmware. Why did you upgrade in the first place ?
I upgraded the firmware because it was supposed to improve DVD-RAM reading/writing performance. I haven't tried reverting the firmware yet as usually most devices will not allow a reversion to a previous version.
I have managed to revert back to the previous version of the firmware (A301), but it has not resolved the problem. So now I am not so sure that the firmware was the issue. Any other suggestions?
Update:
After some trial and error, I've now discovered the following: I don't think the issue has anything to do with the firmware change, but it might have something to do with one of the NERO 6 DVD Writer program components, specifically InCD, that I have installed. I downloaded updates to NERO (Nero 6.3.1.6 and InCD 4.2.4.1) a few weeks ago (before I installed the firmware update) and everything appeared to be going OK, but I hadn't tested a DVD-RAM disc. I've run the InfoTool component (part of NERO) and it came up with the message: ""Drive E: is locked by InCD server. Do you want to release the drive?". When I answer yes, the drive is released and then I can access it. I have to do this each time I insert a DVD-RAM, as otherwise I keep getting the access denied error. This also generates a warning in the event log (event ID 257, source PlugPlay Manager). I've contacted Nero and am waiting for a reply. So at this point I have a workaround, but not a permanent solution.
DVD exploding inside the drive from a drive exceeding 24x. True?
By snafubaby in forum MediaReplies: 10Last Post: 5th Dec 2010, 18:05 -
Most accessible formats for web?
By Xavier in forum Newbie / General discussionsReplies: 2Last Post: 22nd Mar 2010, 23:45 -
Win 7 msconfig boot menu not accessible
By johns0 in forum ComputerReplies: 2Last Post: 10th Feb 2010, 03:21 -
Time/Date Stamp - DVD, Hard Drive, and/or flash drive camcorders
By vanjh9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 2nd Feb 2009, 18:38 -
USB devices not accessible using Explorer
By mats.hogberg in forum ComputerReplies: 4Last Post: 24th Sep 2007, 15:22
