Hi, I just authored my first DVD (with DVD-Lab) and have the following problem: I use one main menu and several chapter selection menus, all with background music. Now I want the music not to start from the beginning everytime I get into a new menu, but to continue throughout all the menus. Is there a way to do this? If not with DVD-Lab, maybe with some other program?
Thanks for your help![]()
The DVD specs don't allow you to do this and I don't think there's any workaround.
It's not DVD-Lab's fault. It's just that it can't be done, with DVD-Lab or any other tool.
Don't make the music too loud. Reducing the volume takes the attention away and it puts it sort of "in the background" but it's still pleasant. Make a transition of some 2-3 seconds between the menus and put a small audio clip that fades out at the end but it starts sort of "loud" to contrast the current audio being played. That should make it less "annoying".
TMPGENc Authoring Works 4: Menu crashes after I add background music
By silentmachine in forum Authoring (DVD)Replies: 2Last Post: 11th Aug 2011, 16:32 -
How to add background music?
By coody in forum AudioReplies: 2Last Post: 25th Sep 2008, 17:04 -
Replace Background Music with New Music without affecting other tracks
By PaulDHolloway in forum AudioReplies: 3Last Post: 10th Apr 2008, 13:56 -
legality of using copyrighted music as menu audio background
By nbi in forum Authoring (DVD)Replies: 3Last Post: 20th Nov 2007, 04:14 -
How to lower background music
By auroragb in forum AudioReplies: 3Last Post: 24th Jul 2007, 21:54
