is there a way to get rid of them or reduce them?
Results 1 to 12 of 12
Hi kazz0817,
Based on the info you've given, take your pick as appropriate:
A higher bitrate.
A better quality source.
A source with less camera shake / fast panning / fast action scenes.
If you can suffer the reduction in quality, encode at a reduced resolution (assuming you're currently encoding to full D1) - say 1/2 D1, but keep a fairly high bitrate.
There's probably others too... These are just the ones that sprung to mind.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
There's also the "soften block noise" option in TMPGEnc.It's on the Quantize Matrix tab of the settings. Macroblocks are not all that uncommon when you are working with divx/xvid sources, which I'm guessing is the case here. I don't know what resolution you are using but try 1/2 D1(352x576) if you aren't already.
will 100kb/s make much differance (increase) Iin resolution?
Originally Posted by kazz0817
i selected that in the advanced tab and it made the dvd screen too big
Change the resolution on the Video tab, not Advanced. It's under "Size".
will it be better encoding at full screen, or fs keep aspect ratio?
Depends on your avi's resolution. Do a test clip with "full screen(keep aspect ratio)" and see how it comes out. Play it with something like Power DVD or WinDVD so it is displayed how it would be on your set-top DVD player. Windows Media Player and the like don't always display the correct aspect ratio.
MEGUI & X264 = Macroblocks
By Cunhambebe in forum Newbie / General discussionsReplies: 1Last Post: 8th May 2008, 10:00 -
DV to H264 at 3100kb/s and still has macroblocks?
By SatStorm in forum Video ConversionReplies: 12Last Post: 25th Jan 2008, 04:39 -
VHS to DV to DVD, Macroblocks on final DVD
By hysteriah in forum Video ConversionReplies: 38Last Post: 20th Sep 2007, 11:20
