None, with the exception of the ultra high end model, appear to have it and I was wondering why. Does anyone have any insight on this?
I mean, how much could it cost considering even some of the really cheap models, the LiteOn LVW5001 for example, have it?
I understand there are some who have argued PQ is the same (some have argued it's better) using analog inputs but it still seems like a critical omission.
Any thoughts on this issue?
Sorry are you talking about standalone dvd players which use digital firewire connections such as Denon Link or Pioneers iLink ?
Well, yes........just your basic DV Input (IEEE1394) that's typically used for the purposes of transferring footage from, say, a miniDV camcorder.Originally Posted by Hardcoreruss
The Panasonic E60 had it but it was omitted from the E55 (probably the closest model in the new line to the E60). I've been trying to second guess Panasonic on this issue. Was this strictly a cost-cutting measure? Do they believe users can get the same (or better) quality by transferring their miniDV footage via analog inputs? Alternatively, did Panasonic do some kind of research which indicated most people were buying their recorders as a VCR replacement rather than for transferring miniDV footage? -
According to Panasonic's press release, they'll introduce the DMR-E65 model with SD slot and firewire input in June, which is a replacement of the previous DMR-E60:
http://www.panasonic.com/consumer_electronics/pressroom/cont2.asp?Filter=12&cont_id=580
It's also very likely that Panasonic will introduce the DMR-E95H which also has the firewire input as their top end model in summer. -
Oh, yeah. Thanks!
I recall reading that press release quite some time ago and obviously forgot all about the E65.
Panasonic PV-HD1000 firewire out?
By Des in forum Capturing and VCRReplies: 5Last Post: 14th Oct 2011, 15:01 -
Panasonic DVD & USB & SD Card Slot Problem
By Tim Sage in forum DVD & Blu-ray RecordersReplies: 1Last Post: 20th Mar 2011, 19:23 -
Panasonic DV Firewire problem
By darrenkarp in forum Newbie / General discussionsReplies: 7Last Post: 9th Dec 2010, 14:28 -
Best Software to Edit VOR & IFO Files from Panasonic RAM Disk & Arc
By JDex in forum Newbie / General discussionsReplies: 16Last Post: 30th Sep 2009, 06:55 -
Need DVD Player To Play DVDrs & CDrs
By DJboutit in forum DVD & Blu-ray PlayersReplies: 3Last Post: 15th Jul 2009, 16:11
