hey everyone, i've been searching for some help on this for over a month (no lie!) and well, i have had NO luck
well, my problem is, i can't burn a dvd faster than 2.4x, i've tried burning video and data
I have a Sony DRU-530A (which is an 8x) and a Lite-On 411S (which is a 4x) (both drives won't go faster than 2.4x)
I am using Ritek DVD-R which is 4x, and i am using Nero Burning ROM 6.3.1.6 which is the latest version i am sure...
my computer is surely fast enough to burn at 8x ( p4 2.4ghz, 512mb ram, SATA hard drives)
in nero, and even in DVD shrink, when you try to select the speed, it only shows 1x, 2x, 2.4x, MAXIMUM, i have tried burning at maximum, but it only goes as fast as 2.4x
any help is GREATLY! appreciated.... i am very sorry if this has been posted before.
Results 1 to 11 of 11
k422
first i would make sure your dvd burner is running dma mode.
check the media you are using to make sure the speeds are acurate. you can use dvdinfo or dvd decrypter for this.
but ultimately, i think you're going to find that this is a firmware issue.
go to the sony website and install the latest firmware. -
Use this method to see wether it is the disc or the firmware:
Open Nero with no disc in the drive. Start a new video dvd (or whatever). Make sure your burner is selected at the top. Throw something in the layout. Click burn and the screen will show up that controls speed selection and etc. With no disc in the drive the speeds available should be all the speeds that the drive supports. I have a 106d. Mine says 4x, 2.4x, 2x, and 1x. -
well, for both dvd rw drives, the firmware has been updated to the most recent ones...
the jumper settings are correct, or else it wouldn't work...although i have 2 sata hard drives, and 3 cd/dvd drives...
the media i used is 4x media,
when i try to do what you said mybook4, it still only says the speeds are 1x, 2x, 2.4x, and MAXIMUM
i used dvd info since dvd decrypter wouldn't work right.... it said the media was RITEK, but i can't tell what speed...
i don't know how to tell which drive is on dma or not... but in dvd info, the internal interface are: sony drive: atapi-2 lite on drive: atapi-3
once again, thanks for your help!!k422 -
to determine DMA on the drive:
right click "My Computer", select propeties, hardware tab, device manager.
find and click the "+" beside IDE ATA/ATAPI controllers
select the IDE channel that your DVD drive is on...usually Secondary IDE Channel....double click it or right click it and select properties.
Go to the advanced setting tab, and you will see 2 devices listed here. Device 0 is the master, Device 1 is the slave. Check to see what it says in the white drop box beside "Transfer Mode"....it will either say PIO or DMA. You need to set it to "DMA if available"....it will also tell you your current transfer mode right below that. -
I have a Sony DRU-500A and even though some of my DVD blanks may say 4x doesn't necessarly mean the drive will burn them at that speed even though 4x may be selectable in my burning application. I think it's a firmware problem or incompatible hardware/media, I don't know. I would consider trying a firmware upgrade, different media, and maybe a different burning application. You may find what is slowing things down. Good luck.
try upgrading your firmware.
here's a link for your drive.
http://sony.storagesupport.com/dvdrw/dru530adwn.htm -
yeah, firmware has been upgraded to the latest, i wish that was the problem, but i guess not
k422
Subs Help - Driving Me Bananas ...
By DaveWillow in forum DVD RippingReplies: 2Last Post: 14th May 2010, 10:40 -
Conversion size is driving me crazy!
By artdog in forum DVD RippingReplies: 8Last Post: 27th Apr 2009, 12:33 -
Printer driving me nuts
By bryankendall in forum Newbie / General discussionsReplies: 4Last Post: 27th Dec 2008, 09:47 -
This file is Driving me Crazy! suggestions plz
By k_oss_22 in forum Video ConversionReplies: 2Last Post: 19th Mar 2008, 00:40 -
Driving the HD DVD Juggernaut
By NICEBUD in forum Latest Video NewsReplies: 9Last Post: 3rd Feb 2008, 11:01
