I've got the Compaq OEM version of the Intel D850GB motherboard with an Intel P4 1.8 and 512 RDRAM.
Intel Active Monitor and several other softwares say I have no temp sensors? WTF?
I thought all P4/Intel boards came with monitors?
I've never worries about this until now ... PC has been on for about 5-6 days straight, with a lot of encoding going on ... I'll power it down overnight if it needs a cool down, but I have work I need to finish.
Anybody have experience at this?
I had an older Celeron and I got a front panel temp indicator with a probe. Epoxied it to the heatsink close to the CPU with a little thermal compound under the epoxy. Worked well enough. You don't have any temperature reading in BIOS, either?
My last PC (a Dell) didn't have a temperature sensor either, not even in BIOS. I would have had to do the same as redwudz if I wanted to see any temperatures. I think it's just one of the things about buying a big-brand machine - they don't expect you to be playing with it so they don't include features like that.
Cobra -
I haven't had any luck finding a monitor for my work PC either. The last one I tried was Motherboard Monitor but it doesn't support the proprietary HP MB I have.Originally Posted by lordsmurf
I'm wanting to get something for when I add the second Xeon to it. It already runs a bit warm. The MB has all the Winbond support chips for CPU temp and fan speed, etc.
I like redwudz's suggestion. Then we're not dependent on some third-party app to detect the temp hardware. Plus, his way is more accurate since thermocouples are orders of magnitude more accurate than thermistors.
Temperature Range
By Seeker47 in forum ComputerReplies: 12Last Post: 6th May 2009, 16:15 -
CPU stays at the same temperature
By videohalp in forum ComputerReplies: 4Last Post: 7th Sep 2008, 15:43 -
temperature and (not of) an LCD TV
By moviegeek71 in forum DVB / IPTVReplies: 4Last Post: 1st Apr 2008, 13:44 -
Checking CPU temperature
By Rudyard in forum ComputerReplies: 6Last Post: 22nd Nov 2007, 17:18 -
CPU-Z reading for Intel Allendale cpu
By budz in forum ComputerReplies: 11Last Post: 8th Jul 2007, 19:33
