Just wanted to ask this if someone is familiar with it.
Is there any difference between either red or black and yellow RCA cables - connectors between VCR or DVD and TV?
My assumption - no, they are just there for easier hookup - easier to recognize.
Results 1 to 11 of 11
They're all interchangable but I use red for audio right, white for audio left and yellow for video.
whiel we're on the subject, i ******* hate tv's & vcr's that only have yellow & white hookeups, and no red..
On expensive cables, yes, big difference. On cheap ones ... no.
Lordsmurf, I assume that you mean there is difference on expensive cables between the video (yellow) and audio (red, white or black). Because in my opion there is no difference between the audio portion (just colour)
red and white cables are identical regardless of quality. as lordsmurf says, the yellow cable is often better on higher end cables. cables are like everything else in a system. you are only as good as your weakest link. high end equipment quickly expose cheap cables.
GuestGuestOriginally Posted by sLiMpAuLy
The only difference in expensive cables is in the video cable. That and they look a lot nicer but you pay more for the look and brand than anything else.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
Agree with what's stated above -> most definitely a difference with expensive cables.
As for cheap -> is the Video (yellow) thicker/heavier (larger diameter) than the red/white? If it is then it's probably better, if it's the same diameter then it probably the same quality... -
There should also be a difference between a "normal" rca to rca lead and a "digital" one for using with your receiver, but i don't think there is really.....
Laptop to Tv no audio with RCA cable
By syboz in forum Newbie / General discussionsReplies: 12Last Post: 5th Mar 2012, 20:13 -
Speaker wire to RCA? cable needed...
By flamy in forum AudioReplies: 12Last Post: 24th Dec 2010, 12:05 -
Red or Yellow?
By olyteddy in forum ComputerReplies: 4Last Post: 21st Nov 2010, 22:39 -
I cant get Svideo to RCA cable to work on my PC to TV.
By awaisuk in forum Capturing and VCRReplies: 1Last Post: 14th Jul 2009, 13:49 -
I need to buy a Quality RCA Audio cable, any pointers?
By faramith in forum AudioReplies: 7Last Post: 7th Jul 2007, 13:25
