Alright I used Adobe Premiere Pro to edit my movie which was captured off a miniDV tape and I have it all edited and ready to go... I am going to author it soon but I was wondering what I need to do to export the movie into a certain file and then put onto my DVD... I know how to export and stuff, but I want good quality on my DVD and the right size and stuff... Thanks for everyone's help!
-rbmerc
SYSTEM SPECS:
: Abit NF7-S v2.0:
: Corsair 512MB XMS DDR3200 :
: AMD Athlon XP 2600+ at 2.01 :
: 80 GB WD HDD 8MB Cache :
: Antec LANBOY Case 350w PSU + 2 80mm fans :
: Sapphire ATI Radeon 9800 Pro 128MB :
: LiteOn 4x DVDR/RW : -
If it's still in DV format, the easy way is to just put it into TMPGEnc encoder and use the wizard. Then into TMPGEnc DVD Author and then burn. The specifics are all covered in the guides to the left.
Best way to copy Home Movie DVD
By quxote in forum Authoring (DVD)Replies: 3Last Post: 18th Jul 2009, 03:27 -
new to making home videos, canburn to DVD but NOT as one movie ! ??
By DoktorDave06 in forum Newbie / General discussionsReplies: 9Last Post: 10th Feb 2009, 14:25 -
Which menu to return to when a movie is finished?
By mmasroorali in forum Authoring (DVD)Replies: 3Last Post: 23rd Sep 2008, 09:53 -
Authoring a DVD home movie
By vikasa in forum Authoring (DVD)Replies: 29Last Post: 30th Aug 2008, 18:29 -
home movie DVD to IDVD or IMovie
By vrobie in forum MacReplies: 7Last Post: 28th Aug 2007, 18:04
