what are the optimum system preferences for making ffmpegx work?i still cant get a peep out of her no matter what i try,so maybe its something minor that im missing?
What do you mean when you say "system preferences"? If you mean the thing that used to be known as the control panel, then the answer is there are no optimum settings - they should have no effect on ffmpegx. You'd be better off posting what your exact problem is
i already have:
https://www.videohelp.com/forum/viewtopic.php?t=217983
i tried that but still no dice:
Encoding started on Wed Apr 28 15:15:08 PDT 2004
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
**ERROR: [yuvscaler] Could'nt read YUV4MPEG header!
**ERROR: [mpeg2enc] Could not read YUV4MPEG2 header: system error (failed read/write)!
ive actually made a little progress here,i saved the movie as "a self contained movie,using QT,then i tried to encode to VCD again.it still didnt work,until i went to "options " and turned on "Decode with mplayer".however after about 10 minutes encoding it failed again,and i got this:
wait, encoding to mp2 audio with mp2enc...
/Applications/Video/FFmpegX/ffmpegX.app//Contents/Resources/mencvcdX: audiodump.wav: No such file or directory
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [mplex] File /Users/davidmurphy/Desktop/bl.mpv looks like an MPEG Video stream.
**ERROR: [mplex] Unable to open file /Users/davidmurphy/Desktop/bl.mpa for reading.
[vanillapowerbook:~] davidmurphy%
any takers?
Convert your audio to WAV with QT Player then to mp2 with ffmpegX. Finally combine mpv and mp2 with the "Mux as.. VCD" tool.
Problems with display of File / Preferences
By Lehmeier in forum Newbie / General discussionsReplies: 7Last Post: 12th Aug 2011, 05:06 -
Take Preferences, Vegas 6.0
By solarblast in forum AudioReplies: 0Last Post: 24th Nov 2008, 10:52 -
M2PMCEncoderZX optimum settings
By Kalash109 in forum DVD RippingReplies: 0Last Post: 30th Nov 2007, 12:52 -
Help File for Preferences & Settings
By jhb50 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 16th Jul 2007, 22:53 -
Can't maximize preferences window in 2.5
By maxxjulie in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 28th Jun 2007, 18:48
