When I use dvtool v. 0.53 to cut a large mpg-1 file into smaller mpg-1 files I encounter a problem. The first piece is ok -- it will play on other Windoze XP machines and TMPGEnc will open the file on my machine. The remaining pieces will not play on other machines and TMPGEnc will not open these files on my machine. Surprisingly, all of the pieces do play on MY computer (using irfanview)! This is the case whether or not I check the sys header box in the options frame of dvtool.
Noxt
I found a program that does the job for me using XP Pro: Easy Video Splitter (http://doeasier.org/).
Noxt
Problem with .vob .mpg files and editing
By rainyday in forum Newbie / General discussionsReplies: 7Last Post: 16th Apr 2008, 23:51 -
Cutting a MPG FILE
By peekayem in forum EditingReplies: 3Last Post: 16th Mar 2008, 09:06 -
cutting out scenes without loss / converting mpg to avi
By denadel in forum EditingReplies: 3Last Post: 19th Jan 2008, 08:18 -
Problem With MPG files in Studio 9
By BillP2 in forum Authoring (DVD)Replies: 3Last Post: 3rd Dec 2007, 06:49 -
Odd Aspect Ratio Problem in mpg files
By nerys in forum EditingReplies: 10Last Post: 14th Nov 2007, 12:45
