Anyone know why the max frame size for capture under Win XP is all messed up. I used to be able to capture to 720 x 480 and now the highest frame size is 720 x 240 ...this is just not good enough. All choices are whatever X 240 - if you set to anything else, you get an error saying the frame size is not supported. I want to cap at 352 x 480, 480 x 480 and 720 x 480.
no worky man - win2k and XP use WDM crap drivers.
iuVCR will allow you to capture the higher rez though, check it out here - http://www.iulab.com/ -
FiEND
WinXP use VfW too.
So you can use VirtualDub1.4.7. with out any wrappers -
Please correct me, if I'm wrong.
If you wont use a VirtualDub under Win2000 then read old news on http://www.virtualdub.org (writed, how with Win2000, 2 Service Pakc and registry changes is possible to run VirtualDub with out any wrappers).
I think WinXP drivers is not WDM or WfV oriented (or WinXP have a build-in wrappers). I just installed WinXP 2600 and last official ATI drivers for XP - 3276, unzipped VirtualDub archive and run Virtualdub.exe.
Capture problems using ATI TV Wonder HD 750
By SKot in forum Capturing and VCRReplies: 9Last Post: 3rd Jan 2012, 16:34 -
PCIe/USB AVI Capture device with SVideo and fully functioning Win 7 drivers
By Spektre in forum Capturing and VCRReplies: 3Last Post: 23rd Aug 2011, 20:34 -
Sharp Mini DV firewire not detected by Win 7 but was working under Win XP.
By thintin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 6th Jun 2010, 03:12 -
How 2 Capture HD with ATI HDTV Wonder
By NautTboy in forum DVB / IPTVReplies: 41Last Post: 2nd Apr 2010, 13:38 -
Win 7 and XP dual boot issues. Can't access one of the drives in Win 7?
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 13th Jun 2009, 23:51
