I have committed a big mistake.I wanted to converted some old video 8 tapes to mpeg2.The video was created using a SONY CCDFX411.So I did some research and decided on buying a PLEXTOR CONVERTX,sounded like a simple process.My mistake was I assumed the camcorder had the right inputs(analog).But its a "RFU ADAPTOR"(1video&1audio),so I'm left with a extra plug (red)from the plextor with nowhere to plug it![]()
Is there an adapter that could use?Any idea's would help?thx in adavance
I came I saw I conquered.........
Sure, if you have a Radio Shack or audio store local, you can get a 'Y' RCA phono plug adapter to convert a mono source into a stereo input. There are both male and female versions available. If the plugs are a different type, you should still be able to find a suitable adapter, they're very common.
complete camcorder virgin looking for a (up to)$850 camcorder
By rocketman122 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 28th Aug 2010, 10:34 -
Which is good HDD camcorder or DV camcorder?
By tapal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 16th Sep 2008, 03:09 -
Analog Camcorder to Digital Camcorder Cable Question
By bradnwa in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 12:47 -
Will cheap new Hi8 camcorder output better than old, worn Hi8 camcorder?
By ErikL7 in forum RestorationReplies: 7Last Post: 2nd Sep 2007, 06:26 -
MiniDV Camcorder or DVD Camcorder
By psxiso in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 9th Jul 2007, 17:13
