I'm very curious. I have a couple of concerts on dvd that were never released. Is there any way to copy the audio portion and then burn it to a cd? Has anyone tried this. Maybe I'm dreaming. Any advice greatly appreciated. Thanks!!
Payware:
DVD Audio Extractor
#1 DVD Audio Ripper
ImToo DVD Audio Ripper
Freeware:
1.Use DVDDecrypter to rip AC3 audio.
2.Use AC3Tool to convert to WAV.
3.Use Audacity to split into tracks. -
For DVD's I want audio off of, I use DVD Decrypter to rip, Headac3he to convert to WAV, and then Goldwave to cut tracks and re-encode to MP3. Goldwave isnt free (its shareware) but it functions for long enough that you can do quite a bit with it before it becomes non-working.
just did a bunch of this, to sample some bits from some movies.
easiest way I found -
- SmartRipper - select "Stream Processing", check off just the audio stream, and select "demux to extra file".
- you'll end up with 5 or 6 files, one of which will be an .ac3 file. delete everything else except the .ac3 file.
- plug it into BeSweet and convert to 44.1khz .wav file.
- use Audacity to edit for length.
all freeware, and once you get the process set up, pretty easy and fast.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Hi,
In using #1 DVD Audio Ripper, I am constantly getting the folowing error:
"MPEG2Dec: Error during reading input file"
I see all the chapters listed and am selecting them to rip. Most resulting .mp3 seem to be cutting off before the end of the "song."
Any sugggestions?
Thanx,
John
Verbatim 94554 CDR vs. 94712 CDR. What's the difference?
By Puppets86 in forum MediaReplies: 12Last Post: 3rd Oct 2010, 16:31 -
Replace Background Music with New Music without affecting other tracks
By PaulDHolloway in forum AudioReplies: 3Last Post: 10th Apr 2008, 12:56 -
How To Rip and Manage Music DVDs just like Music CDs in JRiver Media Center
By jmone in forum User guidesReplies: 0Last Post: 13th Oct 2007, 18:15 -
CDR TO DVD software please
By Lennoxtown in forum Authoring (VCD/SVCD)Replies: 5Last Post: 7th Aug 2007, 12:04 -
Can I burn a music video along with music trax onto the same disc?
By Kalla B in forum Newbie / General discussionsReplies: 0Last Post: 4th Jul 2007, 12:02
