If a DVD Comes with a bunch of extra stuff on it like:
autorun.inf
common (folder)
disc.id
install.exe
readme.txt
win (folder)
after running the DVD through MTR am i able to just drag these files into the folder created by MTR? Will they be transfered over when i use DVD2OneX? Since I am trying to make an exact backup of the DVD, i kinda want all of these files and what not. If anyone knows how i can make sure these still will function please let me know!
Thanks a million!
You can copy all that stuff over to the folder that MTR creates, but DVD2OneX will not transfer them. You will then have to copy them from the MTR output folder to the DVD2OneX output folder before burning. Only the VIDEO_TS folder is encrypted on DVDs, and so you only need to use ripping software for that. The rest can just be copied manually in the Finder, if you want them, and they'll work as expected. Just remember to reduce the user size in DVD2OneX if those files take up a lot of room, so you'll still have space left for them.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
cool.. that is what i figured, but i just wanted to double check. Thank you for the prompt response.
Donald
DVD content on Blu-ray
By michcio in forum Authoring (Blu-ray)Replies: 4Last Post: 10th Mar 2012, 06:45 -
3D dvd content - convert to Blu3D content
By Smells_Like_Feet in forum Authoring (Blu-ray)Replies: 19Last Post: 18th May 2011, 07:52 -
Complex problem, extra some chpts from 2 dvd and combine into 1 dvd + menu
By Shihtzu88 in forum Authoring (DVD)Replies: 1Last Post: 23rd May 2009, 08:09 -
Adding extra data folders to DVD
By schematic2 in forum Authoring (DVD)Replies: 6Last Post: 25th Apr 2009, 11:01 -
burning HD content in DVD
By hanugro in forum Authoring (Blu-ray)Replies: 5Last Post: 22nd Aug 2008, 20:06
