hello,
i have a small problem with DVDmaestro. when i go in to the menu editing window, the bottom and sides of where you can edit the colors of everything is cut off. here is a screenshot of what i mean.
how can i fix that so i can see the rest of what i am missing?
thanks!
Results 1 to 12 of 12
Try increasing your screen resolution. This is my setup at 1280 x 1024 (scaled down for display purposes):
yea my screen is at 1880x1024 as well. i have tried diffrent resolutions as well but they all yeild the same result. any other ideas?
also, those two scroll bars beside the color mapping were never there before either. whats going on? -
Have you tried going to Window > Tile and then 'Allowing Docking' on each window and moving them around? Go to View > Project Tree and post a screenshot of what it looks like with the project tree in place. Peculiar problem you have there. Which version are you running? Have you run 2 different versions on the same system, by any chance?
alright, here is a screenshot with everything docked.
and the same thing has happened. i might have run two versions on this machine in the past once but i dont think i have. also, i have a dual screen setup on this computer, do you think that might be causing this problem? -
ok, i just installed an older version of DVDmaestro to see if that would fix the problem, but it is still exactly the same.
does anyone know why or what i could do to fix this? please? -
Have you tried placing the cursor over the row-resize bar and moving it down? That is if that is a divider that can be moved... try placing the cursor over it and see if you get the twin-headed arrow.
HKEY_CURRENT_USER\Software\Spruce Technologies\DVDMaestro
delete this key and everything in it from your registry
restart maestro
(if you want - back it up first)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
alright, well there are no double headed arrows to resize it. and i deleted that key from the regedit, and restarted maestro but i still had the same problem. am i doing something wrong in the regedit or something?
ok, i just tried to run DVDmaestro on my laptop, and it displayed fine. there were no missing parts of the screen like in my screenshot.
well if you look in that key - you will see positions of all parts of maestro ..
maybe you have to uninstall first -- i dont know ... it ussually works
try changing the resolution of your monitor temp."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
How to write randomizer script in DVDMaestro
By GomezOptions in forum Authoring (DVD)Replies: 5Last Post: 20th Aug 2011, 00:15 -
DVDMAESTRO sx32w2.dll
By twinegar in forum Authoring (DVD)Replies: 1Last Post: 16th Mar 2010, 12:04 -
window live!!!
By Seasonal in forum Off topicReplies: 6Last Post: 14th Jan 2008, 04:43 -
How to add multiple audio tracks in DVDMaestro?
By rbatty11 in forum Authoring (DVD)Replies: 0Last Post: 5th Sep 2007, 07:48 -
dragging a window
By thespook in forum ComputerReplies: 2Last Post: 3rd Sep 2007, 00:33
