  1. Hello,
    I've made a compilation with TMPGEnc DVD Author and i would to burn it with a Regional code.
    I want my DVD only readable on Region 1 DVD players.
    Is there a software or a method to do this ?
    Thanks for your help,
    Apr 2004
    Miskatonic U
    There was a long discussion regarding this over at the DVD Lab forums. The results are a little mixed, with some saying it is not part of the DVD-R/+R spec, some saying it can be done, and some saying it can only be done if CSS is also enable. Have a read here http://www.mmbforums.com/modules.php?name=Forums&file=viewtopic&t=5160 to see if it helps.
  3. Thanks for your response,
    I've found that DVD Shrink 3.1 is able to set a region code when burning the DVD in the Backup button.
    Is there others softwares able to set it ?
    Apr 2004
    Miskatonic U
    Most of the high end authoring packages would be able to - think Maestro, scenarist etc. If you know what you are doing, you might even be able to change it using IFOEDIT.
    My reading of the discussion I posted earlier does raise the question that even if DVD Shrink does set a region code, where does it set it, and will this be obeyed by all region locked DVDs ?
  5. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    ONLY readable on Region 1 players? I'm afraid that is wishfull thinking. One spin through my(any) computer and the result is now Region Free in the hands of even a novice.
    I wouldn't waste my time if I were you. I get Region 1/NTSC discs all of the time and I'm playing them here in Region2/PAL land. It's not worth the effort on your part....in my opinion.
  6. Member holistic's Avatar
    May 2001
    here & there
    Ifo Edit
    http://mpucoder.kewlhair.com/derrow/rce.html
    Reverse engineer this guide.
    An exercise in futility.......enjoy.
  7. So, im curious without specifying a region, will it play region free?
  8. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    When we download programs like DVDDecrypter or DVDShrink....they come to us pre-set to make the resulting rips region free....you can of course change that in the settings. The result will be a region free disc BUT that will not solve the NTSC/PAL problem...that is another hurdle that some need to cross now and then.
    Of course now there are some DVD's that will not play in a region free DVD player....the player must match the discs region code.
    I don't recall ever coming across one of those personally.
