I'm using an ADVC-100 to convert my SVHS tapes and LaserDisks to DVD.
I capture with WinDv (I found this freeware works as well or better than the $40 Scenalyzer I was using). TMPGEnc Plus and TMPGEnc Author then covert the .avi to DVD. I'd like to substitute VirtualDUB for TMPGEnc, but VirtualDUB
doesn't like Canopus .avi. I tried finding the Adaptec DVSoft codec that I heard will make this work, but failed to find it.
Anyone know how I can use VirtualDub with my Canopus output?
Thanks.
Results 1 to 1 of 1
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 19:26 -
Canopus ADVC-100 - noisey/grainy and scaling?
By Gibson's Squares in forum Capturing and VCRReplies: 4Last Post: 2nd Jun 2011, 15:41 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 21:52 -
Canopus ADVC-100 and PCI Firewire card
By spiderbaby in forum Capturing and VCRReplies: 12Last Post: 5th Mar 2008, 09:39 -
Canopus ADVC-100 outputs
By datman in forum Capturing and VCRReplies: 2Last Post: 7th May 2007, 19:24
