i have conversed over 100gig homemovie dv avi to mpeg2 in
tmpgenc and now i saw that when someone moves quickly or do
sudden moves in the movies it flicker when i looked at it on my dvd on my 32" widescreen tv. but it looks ok in powerdvd on pc. this is what i used:
captured in microsoft dv pal 720x576 25fps lower field first in adobe premiere 6.0
converted in tmpgenc with template dvdpal cq 65 upper field first
bitr:7000
motion search:fast
interlace
4:3 pal
tv philips 32" widescreen
I have read that the upper or bottom field selection can help but is it
too late now when its mpeg2 and if its not are i losing quality to do so
so now my big question is can i fix this when the file is in mpeg2 format or do i have to capture all again "hope not!!!!!" beacuse i have deleted the avis!!!
Yes, you've guessed it right, you mentioned all the right effects,
you should have encoded the Avi's again....
Thanks,
Yodel
"Live" picture effect - pictures end up "filmized"
By ANOther1676 in forum Software PlayingReplies: 10Last Post: 14th Oct 2011, 12:59 -
Black and white picture on NTSC television from "region free" DVD
By psears in forum Newbie / General discussionsReplies: 4Last Post: 13th Mar 2008, 14:00 -
Flicker, scanlines and non "anti-aliased" image
By F u r u y á in forum Authoring (DVD)Replies: 2Last Post: 19th Jan 2008, 02:35 -
Looking for "flicker out" transition for FCP
By ehmjay in forum MacReplies: 6Last Post: 24th Sep 2007, 00:47 -
Burned DVD's "flicker"
By markannab in forum Authoring (DVD)Replies: 6Last Post: 27th Jun 2007, 03:45
