Just installed a fan (0.9 W) in my LiteOn 5001. 12v wire soldered to the right side of L11 and negative to the ground pad on mother board without using a resistor. Worked very well. When I turn the power off the fan is off.
Results 91 to 100 of 100
Tried L11 mod - it worked for me too. Little guy on the back left corner of m/b (looking from front of unit). Now my fan only runs during power on.
Thanks! -
I just bought a LiteOn LVW-5001 today. I went to the firmware site at www.liteonit.com.tw/dc/english/download/index.asp. I downloaded the system and drive updates, applied them, then downloaded the next one and applied it. Here's the numbers (with incremental changes in bold):
Initially
010143-1129-E2S5(100-0109)
After applying system firmware LNEA1176.DSU
0101-0143-1176-E2S5(100-0109)
After applying drive firmware LNEA1000.D00
0101-0143-1176-F2SC(100-0109)
After applying system firmware LNEA1180.DS1
0101-0143-1180-F2SC(101-0109)
First, has anyone modified the 1180 firmware to disable macrovision? I've read lordsmurf's info at www.digitalfaq.com/reviews/liteon.htm but it assumes the latest is 1163.
Second, some posts have mentioned LiteOn putting a fan on the 5001 if you send it to them. How can I contact LiteOn to do this? Thanks for any help. -
You can go to:
http://www.ss3f.com/ilo/
Download the ILO / LiteOn SMART Firmware Hacker and patch the 1180.
I do not have a 5001 on hand to try it myself. So do it at your own risk. -
Does anyone know what are new enhancement and fix list for firmware version 1180 ?? , please post here,
Next question: where is the best forum to talks about lvw-5001?? after
forum.liteonit.com.tw went down. -
Good to see you again smartblue ... thought we'd lost you.Originally Posted by smartblue
Mostly PAL:
http://cgi.mgillespie.plus.com/liteon/smf/index.php
Mostly NTSC:
http://www.techolio.com/forums/phpBB2/viewforum.php?f=7
ILO is a LiteOn variant, so keep that in mind.
I'm still trying to get "downgrade-friendly" 1176/1180 hacks. There may be problems in latter fw's after 1163 and those greasy bastards at LiteOn added info that prevents downgrading. I think they freaked out when they saw their forum was being used to discuss hacking of their own machines.Want my help? Ask here! (not via PM!)
lordsmurf, why is that a problem? I mean, if you hack 1176 and call it 1177, you can still apply 1180. And if you hack 1180 and call it 1181, you can still apply a later one. Right? Isn't the worst case scenario that you can "downgrade" by simply changing the number in an older firmware to a higher number? I'm probably missing something, but I'm curious what other problems it might cause.
Originally Posted by DrewmieWant my help? Ask here! (not via PM!)
Liteon LVW-5101
By vmelkon in forum DVD & Blu-ray RecordersReplies: 2Last Post: 18th Feb 2011, 16:28 -
Repairing a Liteon LVW 5001
By Toxie in forum DVD & Blu-ray RecordersReplies: 15Last Post: 19th Nov 2008, 11:49 -
Gateway AR-230 flashed to LVW-5001 , DDW-451s to LDW-451s, SUCCESS!
By FiremanPete in forum DVD & Blu-ray RecordersReplies: 1Last Post: 28th Jun 2008, 22:15 -
Liteon 5001 and HQ mode problems
By oldfart13 in forum DVD & Blu-ray RecordersReplies: 12Last Post: 1st Oct 2007, 00:49 -
Playing vcds on Liteon lvw 5001
By northy44 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 25th Sep 2007, 08:50
