Hello,
I am trying to covert a .avi file that is 23.97fps to 25.00fps.
I have already converted the video to 25.00fps
I now need to convert the audio from 23.97fps to 25.00fps![]()
I have been told to use Besweet to covert the audio to 25.00fps.
I carnt get the besweet program to work though
Are there any other programs out there that allow me to convert my audio .wav file from 23.97fps to 25.00fps ?
Cheers
gsvgaming.net sponsored by 4u-servers
On the left under How To's - Convert - Framerates
The top one by SatStorm is the one I used (ntsc->pal)
https://www.videohelp.com/guides.php?uideid=545&howtoselect=4;41#545 -
I carnt seem to find the bit that tells me how to convert from 23.97fps to 25.00fps
Are they any other program that do it besides Besweet, because i cannot get Besweet to work
Thanksgsvgaming.net sponsored by 4u-servers -
Right ok, my Besweet problem
I download the files i need from here,
http://dspguru.doom9.net/
I just download the BeSweetGUI v0.6 (second one down)
I unzipped that to my C:\
I run the program in wizard mode.
Select all the option i want, 23.97 to 25.00, AC3 etc
I get to the last step, click on GO and notepad opens up and thats it
The notepad file is called Besweet, it does nothing else.
Any ideas ?
Cheersgsvgaming.net sponsored by 4u-servers
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 13:36 -
converting movie ntsc>pal audio-besweet "wav to wav" option not showing?
By extent in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2010, 12:38 -
AC3 to WAV = Wav has no audio??
By RobV in forum AudioReplies: 5Last Post: 31st May 2010, 15:26 -
6ch Wav to 2ch stereo wav
By ranosb in forum AudioReplies: 12Last Post: 15th Jul 2009, 22:45
