Hello,
i have convert an ac3 2.0 to ac3 5.1
when i play the movie on an dvd player with DD
the bass is a little low other sound quality is good,
i have convert it with AC3Machinev0.41
i have tried allot of other settings
but no resoltating. allot of chearcing on the web
doom9 en here i can find allot but not my problem
can some one help me out
grtz burner
ac3 2.0 has no LFE channel and 5.1 does ... since there was no advantage converting 2.0 to 5.1 except quality loss, you shouldnt complain to much ..
you could remix the 2.0 and create a lfe channel by using a bandpass filter and set this level to where you want and then re-encode to 5.1 and remember to switch on LFE"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
this is my settings:
i think i have enabled the LFE already...
i'm sorry but i don't understand dificould technical english
grtz burner -
well since that is not a proper application for encoding ac3 , and as mentioned , converting from 2ch to 5.1 is gaining you nothing .. i can't help much .. some others here will know the correct settings ..
to do it properly though -- you will need to remix the audio .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHHHHHHHHHHHHH HHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH HHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH HHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH HHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH HHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
My Bass in a Cam Recording is to loud ?
By picklepie90 in forum AudioReplies: 6Last Post: 1st Mar 2011, 02:04 -
How Can I Fix This Bass Rumble? (Example Included)
By MrJacobAngle in forum AudioReplies: 4Last Post: 13th Jul 2010, 20:09 -
Removing Bass From Video?
By Tel in forum RestorationReplies: 11Last Post: 19th Jan 2008, 16:19 -
5.1 - Bass Management Question
By scottrwn98 in forum AudioReplies: 5Last Post: 25th Oct 2007, 16:07 -
too much bass
By nick088 in forum AudioReplies: 3Last Post: 18th Aug 2007, 00:40
