Can some help me I am newbie at this converting can some one recommend me programs and how to convert MPEG's and AVI files so they will play on a PAL DVD Player. I have programs like TMPEGnec Plus, TMPEG DVD author and DVD Moviefactory 2. Please Help
First, read the guides.
Then, read some more.
After that, experiment.
If you have a problem check the forums.
If you cant find anything, then post.
Finally create your DVD and be happy.
I dint mean to sound rude, just some advice.
/me/ bites my tongue....Originally Posted by x21x
Ditto the above...
makntraksIn the theater of the mind...
It's always good to know where the exits are... -
I’m really surprised that you haven’t taken a thrashing yet, the problem with your post is it’s very obvious that you have not done any research at all with the ‘how to guides” or did a search in the forums. People here are more then willing to help with problems but first you need to utilize the abundance of available resources first.
I have done the research but I just do not where to start with what guide to use and what programs are the best. And most of all easy to use
Use TMPGEnc to convert to DVD compliant mpeg and import the clips into TMPGEnc DVD Author to create your DVD. Are these the easiest and best programs to use? Some might say yes, some might say no. The point is that only you can determine that. You can find guides for each program by clicking on the links in this post.
He would have but I'm trying to play nice.....Originally Posted by loughary
See my sig...
Heres some help on how to use this site.
1 You want to convert AVI and MPG files to DVD , so you click on the 'How to' 'Convert' button on the left.
2 You have TMPGenc so you click on 'How to convert to DVD using TMPGenc' , That will take you to the apropriate guide.
That's it. 2 clicks.
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 9th Apr 2009, 23:56 -
Converting/examining my video files and converting to have less pixelated?
By SimpleSimon in forum Video ConversionReplies: 51Last Post: 28th Aug 2008, 23:33 -
Converting songs purchased on itunes and converting to mp3
By maroonx in forum AudioReplies: 1Last Post: 23rd Jan 2008, 00:17
