  1. Hi to all,
    i have the following problem! I copy the dvd with dvdbackup-dvd2oneX-Toast 6 and the the movies i copy can be played in all dvd players, but not in my emac and Power Book !!!! it comes out something like error code 00099 or something like that!!!!
    thx
  2. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    1. what app are you using to view it? DVD Player? VLC?
    2. did you do anything special to the dvd, remove portions for example, if so it wont load in DVD Player but should load no problems in VLC
    try VLC and see if it can play the dvd
  3. hi
    i try to run the dvd with dvd player!!!
  4. i compered the dvd shrink (windows) with dvd backup and ripper and realized that shrink is a lot faster than anything and i dont know why!!!
  5. Member galactica's Avatar
    Jan 2003
    dvd backup is OLD SCHOOL, slow and unreliable
    use Mac The Ripper......
    not sure why its not playing in your macs, the only way is if for some reason its not standard dvd structure........ like you played around with the IFO's or manually edited content out by replacing the .vobs
    did it play in VLC? www.videolan.org
  6. Member WiseWeasel's Avatar
    Jan 2003
    Silicon Valley, CA, USA
    Do the DVDs mount in the Finder on the eMac and PowerBook? What version of MacOS X are they running? Do you burn to DVD-R media or DVD+R media?
    As for DVDShrink vs. DVD2OneX, make sure you are comparing them on comparable hardware. I mean, if you're running DVDShrink on a P4 3 GHz and DVD2OneX on a G4 800 MHz, then obviously, there will be a difference in speed. Also, different DVDs take different amounts of time to compress, so make sure you're testing the same DVD on both.
    I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
