Hi. I'm going to invest in a DLT recorder to be able to submit DVDs for replication.
Is there only ONE standard in DLT drives/media, so can I just buy a used DLT that has been used for backup in a computer company, or are there spesific standards I need to know of.
Thanx in advance if anyone can answer.
regards
Terje Oegema
Norway
AFAIK there are about three different densities 20gb 40gb & 70gb . The individual drives are generally backward compatible but you cant use 40 or 70 on a 20gb drive.
DLT2 dlt3 dlt4 and I think there is now a DLT super. this is all guesswork tho and not gospel.Corned beef is now made to a higher standard than at any time in history.
So, this means that you think that I can use any DLT drive? Because my DVDs are no bigger than 7,9 GB MAX anyway.
regards
Terje
DVD-5 to DLT, necessary?
By sdsumike619 in forum Video ConversionReplies: 5Last Post: 10th Aug 2009, 21:00 -
Does this mean my DLT is in fact NEW?
By sdsumike619 in forum Authoring (DVD)Replies: 2Last Post: 19th Jun 2008, 22:36 -
Supermediastore.com DLT IV tape - $17.99
By sdsumike619 in forum MediaReplies: 2Last Post: 10th Jun 2008, 15:36 -
Bought DLT 8000 - what do I need to hook it up?
By sdsumike619 in forum Authoring (DVD)Replies: 10Last Post: 9th Jun 2008, 17:28 -
Is it possible: Write ISO images to DLT?
By sdsumike619 in forum Authoring (DVD)Replies: 5Last Post: 8th Jun 2008, 21:09
