Hi - Hope someone has a few ideas on this one!
I'm using NVE to burn DVD using 16:9 AVI's from my JVC camcorder. Problem seems to be that the resultant DVD (or exported MPEG file) seems to have a problem with its interlacing - it looks like the frames have their field order the wrong way around OR they have been encoded as progressive. When playing you get a sutter/gost on each frame as playing. If I take the same 16:9 AVI and push through TMPGENC with output set to Interlace - Field Order B - all works perfectly.
Any Ideas? Does anyone know what encoder NVE uses and are their any "Hidden Switches"? Can you change any of the settings of the encoder?
Nathan
