Does anyone know of any software which will encode multiple avi's to vcd.
For example:list say 4 avi's to encode and they will be done one after another allowing you to leave pc on overnight to encode.
Thanks for any help given...
Closed Thread
Results 1 to 22 of 22
you can do batch encodes using tmpgenc.
load up the avi, choose settings that you want and then click on file | encode as batch =>mpeg (not exact verbage, but it's similar)
you should see a new window pop up with a queued list of jobs.
click on run to start encoding.
However to set up 4 files that are the same would only take about a minute.
The latest versions of TmpGenc will also encode multiple source files to a single mpeg. The files need to be named something like file01.avi, file02.avi...
Only one project needed.
Thats news to me, what version is that ?
Or you could use MainConcept - has batch encoding (will also encode multiple source files to a single mpeg)
ALL popular encoders can do this, CCE being easiest to set up, just drag and drop all the avi files into the cce window, then configure each by doubleclicking on the encoding list. CCE has "always" supported multipple input files to convert to 1 mpeg file also, click the settings button in the input-file frame, and you can even edit frames to include from each file listed there, ideal for DV conversions.
Andyp1 got it right, and i must asume now that you are kind of new to this stuff, so i add a little here..
Heres the avisynth script you need for CCE (still Cinema Craft Encoder) if your AVI files are not in VCD resolution, i recommend doing audio separately:
AVISource("c:\YourAVIfile.AVI",False)
BicubicResize(352,240,0.0,0.6) #use 352,288,0.0,0.6 for pal
ConvertToYUY2()
#next lines only for AMD compatibility
ResampleAudio(44100)
function ResampleAudio(clip v1, int rate) {
v2 = Blankclip()
v1 = AudioDub(v1,v2)
return v1 }
Copy to notepad and save with .AVS extension, make 4 copies and configure each to point to the correct AVI file. Possible you dont need the ConverttoYUY2() line. If framerate conversion is needed then add a line right after AVISource saying ConvertFPS(25) for pal or ConvertFPS(29.97) for NTSC. Deinterlace is "usually" not nesessary, look up ConvertFPS at avisynth.org if needed. And.. Of course you need to install AviSynth for it to work
Originally Posted by dafreak
I have about 40 avi files i wanna convert to vcd and put on a dvd, tmpg will do batch encode from avi to mpg and (s)vcd2dvdmpg will do the batch conversion to be loaded into dvd-lab but i cant find anything that will do a batch encode to rip the wav from the avi, i would like something where you can just point to a single dir and it will do all avi files in the dir, much like svcd2dvdmpg does.
just load them up in TMPGEnc with the VCD template, then hit ctrl+alt+m after every file loaded, then click Run in the batch encode window.
you can deal with the audio portion of it after the video is finished.
I do all my video encodes in batches.
once it's done, I load all the avi's into goldwave and batch process the audio to wave.
then I use tmpgenc ac3 plugin to batch encode the wave files to ac3.
I spend a total of maybe 20 minutes setting things up and just walk away.
I think I spend more time authoring the dvd then I do setting up my encodes.
TMPGEnc source creator is very easy to set up for batch encoding and has 30 day free trial. Doesn't require seperate handling of audio and video. It will output audio as mp2 or wav in perfect synch. You can use ac3 if you purchase the product with the ac3 plug-in. It can combine the files to one video or output them seperately. Hope this helps
just got goldwave, converted 8 files probably quicker than virtualdub does and can do files from multiple folders or a whole folder, i think i found my prog, thanks dafreak
I am sorry that I am posting the same message at several threads, but I need your help real bad.
I use the TMPGEnc Batch Encode, but most of the time, TMPGEnc automatically closes itself after first file encoding; that is, I expect it to encode all files in the batch encode list, but the program closes itself after it finishes encoding the first file in the list (or it sometimes closes itself after 2 or 3 files).
Does anyone know why?
Thanks a bunch
Tommy
You are in breach of the forum rules and are being issued with a formal warning. Quit hijacking months-old topics. Post a new topic ONCE and wait for an answer.
/ Moderator lordsmurf
Originally Posted by DVDFan99
In before theIf in doubt, Google it.
Convert Multiple Files
By jimiy in forum Video ConversionReplies: 1Last Post: 24th Jun 2010, 18:22 -
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 08:27 -
How to convert multiple avi's to DVD with chapter points between each?
By Pierre1 in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2009, 07:38 -
mkv - deleting multiple audio tracks & subtitles - then convert to avi
By fme008 in forum Video ConversionReplies: 2Last Post: 24th Mar 2009, 06:12 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 02:28
