My burner has the 2.0H firmware. I even went vack to 2.0F with no luck. The drive will not recognize the DVD+RW media. Even the Sony disc that came with my burner will not see it. It did some time ago and I burned and erased it a few times, but today it wouldnt. I went out and bought some Memorex 4X DVD+RW and it does not see them either.
I have various brands of DVD-R (x2 and x4) and it saw them fine (I have no DVD-RW media to try)
Any one else have this problem??
Any one offer a solution??
thanks!!!
Tried to burn an RW today, and my 500a will not recognize ANY rw media. That includes both +RW and -RW, Sony, TDK, HP, Princo.
I also downgraded to 2.0f with no effect. -
I've had no problems with Sony 2.4x +RW in my DRU-500AX, original firmware.
upwards of 40+ burns on each of 3 discs...- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
On teh sony support site where you downloaded that FM there should be a link to a live chat with a tech support person who might have ideas.
I had a problem develop with my DRU-500a that it wouldn't write to DVD+/-RWs and started writing 2x to 4x DVD-R media. I don't know if this is the same as yours as mine did recoginize the RW media but stopped erasing them or burning to them. In my case it turned out to be a dirty lens. I was able to correct the problem and now I get 4x write speeds on the DVD-R media and I'm able to erase and write to DVD+/-RWs. See: https://www.videohelp.com/forum/viewtopic.php?t=213846&highlight=
sony dvd rw dru-190a problem
By videodude1966 in forum DVD & Blu-ray WritersReplies: 2Last Post: 17th Apr 2010, 04:53 -
Problem with Sony DVD RW DRU-830A
By VOD0708 in forum DVD & Blu-ray WritersReplies: 6Last Post: 10th Jan 2010, 15:43 -
Toshiba DVD Drive does not recognize Philips DVD-R media
By garybeck in forum DVD & Blu-ray WritersReplies: 12Last Post: 5th Nov 2007, 13:57 -
where to get original Sony DRu-820a DVD Firmware
By scustalow in forum DVD & Blu-ray WritersReplies: 1Last Post: 15th Jun 2007, 12:00 -
By bjswitz in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th May 2007, 09:41
