which do you guys think is better?
any input??
I know the hp 420i is really the nec 2500a that is all i know ,,
I have the Plextor 708A. No problems with this drive. It burns flawlessly using the following brands of dvd media, TDK DVD-R, IMATION DVD+R 4x speed that can be burned@8x with 708A, MAXELL 4x DVD-R, FUJI (TAIYO YUDEN) DVD-R 4x & VERBATIM DVD-R. Those are the recommended brands of dvd media that Plextor supports. I also use the compatible brand RITEK DVD-R 4x G04 orange landscape discs and COMPUSA DVD-R which is manufactured by PRINCO which is known to be crappy media. The only brand that I had a problem with is MEMOREX DVD+R 4x which some of them are manufactured by CMC which is also known to be crappy media.
All of the above burn great and playback on my standalone dvd players. As well as in PANASONIC & SONY standalone dvd players. Some may say the Plextor 708A is picky about media. If you use the recommended brands of dvd media there should be no problems. Some blame the drive when it could be the brand of media being used. Lots of variables in burning dvds to the brand of media you use to the software you use to create the disc and how the drive is set up in you computer.
Good luck on your purchase.
Plextor DVD Burners?
By wulf109 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 12th Jan 2012, 18:01 -
Plextor PX-B310U
By ruktuim in forum DVD & Blu-ray WritersReplies: 1Last Post: 29th Apr 2009, 13:46 -
Plextor PX-AV200U or ???
By wtsinnc in forum Capturing and VCRReplies: 4Last Post: 11th Nov 2008, 13:46 -
Plextor PX-760A
By SCDVD in forum DVD & Blu-ray WritersReplies: 1Last Post: 24th Aug 2007, 01:24 -
Plextor M402U
By LeFreak in forum Capturing and VCRReplies: 5Last Post: 6th May 2007, 21:33
