Is there a way to copy a DVD that will play in all standalone DVD players?
Yes, find a company that press DVD ROMs and make them copy it for you. To keep the costs down i suggest you use DVD-R and burn at 1x, thats the second most compatible way, as DVD-R is the format supported by the most older players.
Originally Posted by jpnkyle
the long answer is, DVD-R and DVD+R have varying levels of playability in the thousands of players out there. If the player is within a year or two old, you have between an 85-95% chance that it will work.
But the only way to be 100% compatible is to use a factory-pressed disc, not a burned disc.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
The answer is ....
YES.
Make a 2 disk set, one burned on a +R disk and the other burned on a -R disk. Then any dvd player that will read a burned disk will play one of those disks.
So far though I never had a -R disk fail to be read that I had burned with Tmpgenc DVD authors built in burner.
Your burning software is just as much to do with if the disk is readable or not by various players it seems. Or at least it was. -
There are still many dvd players around that will not play any kind of burned disks, so your answer would be NO. Only DVD-ROM will play in all players and you cant make it at home. There are some companies doing it, in Philippines and Malaysia can be done quite cheap, but you would need to order MANY copies. Better forget it and stick to expensive DVD-Rs, should work in 93% of all players according to this site.
Can't play homemade DVD copies on player
By poz3614 in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2010, 06:26 -
Region Free DVD-R Copies
By Live2WinForever in forum DVD RippingReplies: 7Last Post: 22nd Mar 2010, 14:18 -
LG LHB953 not playing burned copies of my DVD's
By SMaldo in forum DVD RippingReplies: 8Last Post: 3rd Jan 2010, 21:43 -
Organising DVD copies on external HD?
By terrypin in forum Newbie / General discussionsReplies: 5Last Post: 1st Feb 2009, 08:43 -
DVD copies
By JimboS in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2007, 22:33
