  1. I tried dvddecryptor and it made them into .VOB files again. I need to make them mpeg or avi so I can edit them with software.
    Thanks,
    John
  2. Member teegee420's Avatar
    Dec 2003
    Southern California
    Most of the time simply renaming them to .mpg does the trick.
  3. Member shardison's Avatar
    Mar 2001
    California
    Use VobEdit and demux. Just renaming makes for problems.
  4. I've tried that, but it makes dead space at the end and doesn't want to edit without crashing the computer.
  5. Member teegee420's Avatar
    Dec 2003
    Southern California
    Apr 2004
    I would have to agree that using VOBEdit is the best first step in working with your VOBs. Demux them first, that way you can remove any subtitle and additional audio streams. Once demultiplexed, you can then do as you wish with the elementary streams.
