Is this posible: make a automated routine/schedule for maintenance?
EG: Run adaware than close it, then spybot then close it, then window washer then close, then defrag w/ diskeeper then close. etc., etc.
do i need to know command line options for thes progs...?
thanks in advance
Results 1 to 9 of 9
Win2K or XP?Originally Posted by mujahid7ia
search for "run as a service" on google.
The use the AT command
or check to see if either programs have command line switches. Then put it in a batch file, then use AT command -
XP
What's an AT command?
I don't know if all those apps can run as services. That was an example, I have other progs to add to the maintenance list.
Will a batch file allow me to wait until the program is doen w/ an operation then close it and start the next program? -
First of all, it's good to see you back, mujahid7ia!
I don't know if this will be any help, but here goes:
Start --> All Programs --> Accessories --> System Tools --> Scheduled Tasks
You can get a program to launch from this, but I don't think it does much else unless you can get the program itself to do the task upon launch. Have a play and see if it's any good.
Cobra -
There is a place in task scheduler to add command lines.... I guess I'll have to find them for all these apps and try to estimate how long each will take and set an end time, and hope none will have errors I have to press OK for...
There must be an easier way then this... Im gonna search for some software to help me. -
Adaware did not launch at specified time...
perhaps there is a macro tool i can use
[searching google, download.com] -
Script to Batch edit MKV files with MKVMerge or any other program
By Animebuster in forum EditingReplies: 3Last Post: 21st Oct 2013, 19:17 -
Recommend a batch conversion program for mkv to wmv?
By yoda313 in forum Video ConversionReplies: 2Last Post: 23rd May 2009, 07:58 -
Hi, need a program to batch multiplex.
By mmdmmd in forum AudioReplies: 2Last Post: 18th Oct 2008, 14:50 -
Hi all, I need program to batch de-multiplex mpg files with 2 audio tracks
By mmdmmd in forum AudioReplies: 4Last Post: 14th Oct 2008, 16:57
