Hi,
Does anyone use tmpgenc to create DVD's and if so is the quality good?. If so would you be so kind as to share it with me as the default template does not produce good results (PAL not NTSC)
Cheers
Zed
https://www.videohelp.com/convert/dvdpal.zip
if space is not a problem use as high bitrate as possible to increase quality. -
I'm trying to put Pearl Harbor on a dvd-r (4,7gb) but the movie is too big. Some people say that i must re-encode it.
Wich template must i use to reduce file size ?
<font size=-1>[ This Message was edited by: mgs666 on 2001-11-07 15:45:44 ]</font> -
mgs666: if the source is dvd please post dvd ripping/encoding/copying question in the dvdripping forum.
DVD Cover Templates !
By MLOR in forum MediaReplies: 8Last Post: 23rd Jun 2010, 04:20 -
Printable DVD Slipcover Templates
By nwo in forum MediaReplies: 0Last Post: 24th May 2010, 17:04 -
Tmpgenc Xpress 4 : any PS3 templates?
By lapino in forum Video ConversionReplies: 0Last Post: 12th Mar 2008, 08:34 -
DVD templates
By anfield7 in forum Newbie / General discussionsReplies: 2Last Post: 3rd Dec 2007, 01:16 -
DVD Templates and encoding
By Canadian* in forum Authoring (DVD)Replies: 2Last Post: 24th Sep 2007, 18:11
