I would be very grateful if someone could give me a usefule hint to solve my problem:
I try to use the CCE Adobe plugin with FlaskMPEG and why I start converting it stops after a few seconds displaying the following error message:
cce encoding failed: ***Could not write to the file <c:\videoOut>
Windows error code: 0x6 6
MAYBE it is simply impossible to use the Adobe plugin with FlaskMPEG. I really don`t know what to do.
Problem; You're using an illegal version...I assume you just used the plugin crack but not the registry patch.
Solution: But Adobe Premiere and CinemaCraftEncoder both come with nice manuals and good installation explanations. Even if a problems arises then you can phone their help desk and they'll very nicely help you.
Is there a software or plugin?
By schematic2 in forum Newbie / General discussionsReplies: 4Last Post: 18th Mar 2011, 21:43 -
The Best Video Plugin Ever!!
By DemonSeed in forum Media Center PC / MediaCentersReplies: 20Last Post: 18th May 2009, 13:59 -
vegas plugin
By wingfan in forum EditingReplies: 5Last Post: 10th Nov 2008, 10:33 -
quicktime plugin
By geonuine in forum Video Streaming DownloadingReplies: 7Last Post: 17th Jul 2008, 20:38 -
Cinemacraft Encoder..Black void after encode
By Soixante in forum Video ConversionReplies: 6Last Post: 28th May 2008, 04:43
