I have problem converting DivX to VCD source clip.
I have a movie clip in DivX and avi extention format so not sure it is really avi or Divx format but when I click directly on the clip I see only sound with like 3 seconds of video and the rest is black without any images, just sound. When I put this clip in TMPGEnc Plus (latest version)
and try to encode it to VCD source, I get a clip without video when it's done. I also tried TMPGEnc DVD Source Creator (DSC) and it came out with the same result. Wondering what went wrong?
1. Is it because I don't have the the codecs to watch it therefore can't encode it?
2. Or it doesn't matter whether you can or can't watch if you encode it the correct way in order to convert to a working VCD clip? So are watching and encodeing separate issues and not related to the codecs or but of these these need to have codecs in order to watch and to encode?
3. What kind of codecs if it's the case that I need it in order to watch or to encode, to have and how to install/test to make sure that it's properly running?
4. So when you see a clip and you right click on it and see the "Properties" and under "Type of file" it says AVI, is it really AVI or DivX or Xvid for that matter? Any way to test to know it's what and what. Sorry about asking silly thing but I don't understand much about this matter.
Thanks for helping out. Appreciate very much
meocat.
Which codec is better? or it's a good idea to install more than one codec?
Can I encode to VCD mpg without codecs and have a working clip? -
You will need to install only the codecs (coder-decoder) required to open and play back your files. You can have many codecs installed, but it's best to avoid codec packs as they can result in conflicts. Gspot is the tool to tell you the required codecs.Originally Posted by meocat9
You can encode to VCD, which is mpeg1, but you may need to install a codec in order to decode the source file.Can I encode to VCD mpg without codecs and have a working clip?"Art is making something out of nothing and selling it." - Frank Zappa
I use TMpgEnc to convert MOV to DIVX. But the quality of AVI isn't good
By natong in forum Video ConversionReplies: 0Last Post: 11th Apr 2009, 01:21 -
Subs & Filters in Tmpgenc DSC
By marioval in forum Authoring (DVD)Replies: 5Last Post: 24th Apr 2008, 11:34 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07 -
Does TMPGEnc DVD Source Creator 4 convert Divx(Avi) with audio?
By Plarocks in forum Authoring (DVD)Replies: 9Last Post: 10th Sep 2007, 18:11 -
How to convert Mpeg2 to DivX using TMPGEnc and SimpleDivX
By rwmol in forum User guidesReplies: 14Last Post: 30th Jul 2007, 00:57
