Hey guys. I'm having a little trouble converting from DiVx to MPEG2 video. I am using the latest version of TMPGEnc to do the conversion, and upon successful completion of the conversion, I check the video to make sure everything went correctly. Well, when playing in WMP or a program such as WinDVD, I get sound, but no video whatsoever. The video is just black.
Here's what I'm working with:
- DiVx video is encoded using DiVx 5.1.1 via Premier Pro using a 1-pass VBR and an encoding rate of 4Mbps.
- I am using TMPGEnc version 2.5, and upon conversion, am using all default settings.
Can anyone help me out with this?
Do you see the video in tmpgenc if you use file->preview? if not then try change the directshow priority in tmpgenc.
www.dvdrhelp.com/tmpgenc#problems
Problems converting H.264 AVC to MPEG2
By Gwar in forum Video ConversionReplies: 8Last Post: 4th Jul 2011, 11:29 -
Problems with converting avi to mpeg2 with HC enconder...
By sgbd in forum Video ConversionReplies: 2Last Post: 29th Nov 2010, 04:07 -
Converting MKV to Mpeg2 audio problems
By anfield7 in forum Video ConversionReplies: 1Last Post: 22nd Feb 2010, 07:39 -
TMPGEnc problems with RMVB -> Mpeg2 conversion
By rebel316 in forum Video ConversionReplies: 2Last Post: 7th Aug 2007, 04:33 -
How to convert Mpeg2 to DivX using TMPGEnc and SimpleDivX
By rwmol in forum User guidesReplies: 14Last Post: 29th Jul 2007, 23:57
