ok..i appologize in advance for the noob question but hey)
ok im trying to put a full season of a tv series on a dvd ...i starting with a combo of avi and vcd mpeg's. what i want to know is, is it possible to get them all on one dvd? the quality is simple tv rips so im not gonna go anal about quality but is this even possible? also i heard of an option to simply put the vcd files on a dvd (thus fitting lots more on the blank)
ok i guess thats it, any help or advice is much appreciated!!
andthensome
jose
ps. the total time of all files is 4:55
Convert your avi files to low resolution dvds, either 352x240/352 or 352x480/576. Calculate the bitrate by set the output file size to a dvd size minus all the vcd files and set the runtime to all avi files.
The VCD files can you add directly to tmpgenc dvd author, no reencoding is required. Check the vcd to dvd guides under author. -
thanks for the quick reply....last questions:
1: will kvcd work the same as vcd files (no reencoding)
2:to calculate space,how much space should i leave for menus and such?
thanks alot!!
Max Video Bit Rate upto which FLV can be encoded
By alntke in forum Video ConversionReplies: 9Last Post: 4th Oct 2011, 19:05 -
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2010, 00:35 -
How to get max clear stills, when pause a video - should I deinterlace??
By vantechmag in forum EditingReplies: 2Last Post: 11th May 2009, 18:55 -
How to get max. quality while resizing video
By newnews in forum Video ConversionReplies: 4Last Post: 6th Apr 2008, 16:36 -
Best way to convert a video to iPod with max quality and min filesize
By Salva Veritate in forum Video ConversionReplies: 1Last Post: 4th Jan 2008, 11:34
