I have a big problem with my computer mouse.
Sometimes it the cursor only stops fore a couple of seconds and its very very annoying!!
Do anyone know what to do or has had the same kind of problem??
Results 1 to 9 of 9
What type of mouse is it ? Optical or Regular ? if it's regular, have you tried cleaning the ball area ?
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
its a wheelmouse and yeah i have cleaned it and all that
Thats not the problem unfortunalty.
I can´t figure out what the problem can be.. -
Do you have the possibility to try the mouse on a different PC or another mouse on your PC ?
Best Regards,
Sefy Levy,
I'm assuming it's not a USB mouse which can be a whole other set of problems. One thing you might try is reinstalling the mouse driver. Deleting the device from My Computer / Properties / Devices and rebooting is a possibility. IF it's a Microsoft mouse I would recommend downloading the most recent version of Intellimouse (5.0 I believe) from Microsoft (it's free) and installing it. Should take care of any driver issues
if it's a wireless mouse then your mobile phone or wireless network may be interfering.
It's also possible that something is using up all your resources. My internet PC is only a AMD K6-2 350. It's running eMule all the time, and periodically that program uses 100% of processor time, freezing the mouse cursor for a second or so when this happens. You could have something running doing a similar thing. Just another possibility.
Ethernet (n): something used to catch the etherbunny -
I have the same problem. I am using a Logitech Wireless Optical USB mouse on a WinXP Home OS.
It only seems to happen immediately after closing a program so I just assumed it was just hiccuping while that closed program was being put to bed.
I'll watch your responses to see if someone has a solution. It is kind of irritating.If it works, don't fix it. -
USB 1.1 is ten times more likely to do it than USB 2.0.
I refuse to use a USB mouse unless its connected to USB 2.0. The mouse freezes for a couple of seconds every time the CPU is loaded heavily.
Mouse problem = looking for new mouse.
By Stealth3si in forum ComputerReplies: 14Last Post: 12th Nov 2011, 04:25 -
VCRs, cable box, cable mouse, problems
By judybr in forum Newbie / General discussionsReplies: 0Last Post: 2nd Sep 2010, 13:42 -
2 Problems in WE Re: Showing Video File Info In Columns and Mouse Hover
By OllyPomm in forum ComputerReplies: 5Last Post: 13th Aug 2009, 19:56 -
Mouse Problems with Laptop
By DrFaroohk in forum ComputerReplies: 4Last Post: 13th Mar 2009, 06:38 -
Mouse problem
By yogart in forum ComputerReplies: 2Last Post: 24th Jun 2007, 05:40
