I have recently been having a problem..... i am doing divx to VCD conversion, in the process i usually convert the Audio to WAV. On this occasion the audio format was VBR mp3, when opened in virtual dub There was a popup saying that vbr values will be encoded in to regular cbr values. I continue, but when i go to save to wav but it doesnt fully save the wav file. I have tried other progs like goldwave and besweet they were kinda complicated, with goldwave i have no idea what to do i click open and select the divx source and it says decompressing.... it takes a while and was creating files over 1 gig so i aborted it. Be sweet i just didn't understand at all. Some one recomended nandub so i could save it to seperate MP3 than convert it to WAV, but ive downloaded nandub frm numerous sources and it didnt come with the required dll files.... couldnt find them anywhere either.
Any help with this Problem would be much appreciated
Jake
Try following this, always helped me when there was a VBR MP3 Audio
http://sefy.iwarp.com/guides/wavextract3.html
The "Decompress" program comes from AVI2VCD program you can get:
http://home.cogeco.ca/%7Eavi2vcd/Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
I use Goldwave, it can't be any easier. Load your avi then save..that's it. A typical wav file for a movie will be about 1 GB, it is uncompressed audio after all.Originally Posted by Heckler"Art is making something out of nothing and selling it." - Frank Zappa
I don't think so because.....Originally Posted by Tommyknocker
AC3 is usually used when creating a DVD."Art is making something out of nothing and selling it." - Frank Zappa -
You might get a more accurate result if you demux the audio to mp3 and then use lame to decode to wave
Last thing.... isn't there a setting in VirtualDub that will append (chop off) the audio if it is longer duration than the video? If VirtualDub can't read VBR audio very well, it might consider the audio longer than it actually is.
(It's in "Video" menu / "Select Range")
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 13:36 -
converting movie ntsc>pal audio-besweet "wav to wav" option not showing?
By extent in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2010, 12:38 -
6ch Wav to 2ch stereo wav
By ranosb in forum AudioReplies: 12Last Post: 15th Jul 2009, 22:45 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 03:55
