I am wanting to figure out how to convert a file saved in nero digital back to a mpeg-2 so I can write it to DVD?
I know you can do this for other formats, like xVID, divx, etc.
But I can't figure out how to do it with nero digital.
I'd like to store a lot of file in nero digital but be able to convert that format to dvd to be played in a normal player.
Any advice on how to do this? Or should I just use divx to store them or xvid?
thx
My advice is use Nero Digital only when you don't plan on watching your backup on anything other than your PC. If you have the DVD that you were able to convert to ND, just backup the DVD to DVD-R. If you no longer have the DVD and you absolutely must convert the mp4 files to DVD, don't expect the quality to be good.
You can convert the mp4 to mpeg with TMPGEnc, the TMPGEnc MOV Plugin and a current installation of Quicktime(version 6 or greater). Once you have everything installed TMPGEnc should be able to open the mp4 files, you just have to move the "files of type" slider to "all files". Use a resolution of 352x480(352x576 for PAL). If you use 720x480/576 the picture will probably suffer from heavy pixelization.
How To Convert Nero Digital Video To Normal DVD?
By Laz Baz in forum Authoring (DVD)Replies: 11Last Post: 6th Feb 2012, 04:59 -
Best way by using MPEG STREAMCLIP to convert MPEG2 Muxed at 720 x 404 ?
By DTRON in forum Video ConversionReplies: 1Last Post: 21st May 2010, 16:22 -
Nero Digital AVC to DVD
By Arlo in forum Video ConversionReplies: 1Last Post: 17th Oct 2008, 04:35 -
Eureka! -- Making sense of MPEG-4 Pt. 14, MP4 and Nero Digital?
By GrayStrickland in forum DVD RippingReplies: 3Last Post: 4th Apr 2008, 17:09 -
Convert my digital photos to a DVD
By hufri01 in forum Authoring (DVD)Replies: 5Last Post: 7th Mar 2008, 05:16
