Been using Divx and many other Codex's for years now, but recently I formatted myhard drive and did fresh Windows XP install, followed by service pack 1 and then www.windowsupdate.com for critical updates.
Anyways, now when I go to install my divx packs, that have been working fine for me for years, I can't see the codex's in Virtualdub or DVD2AVI. Here's the install files I use:
SLDcodecpackV1.3 (all DivX Codecs).exe
DivX412Bundle.exe
DivX503Bundle.exe
They been working fine forever and now they don't come up at all. I have a sneaky suspision it may have to do with the windows updates trying to clamp down on security and maybe restricting divx for some reason. Just a suspision though, I have no way to prove this...
Any advice or help would be greatly appreciated.
Thanks.
rhuala
What do you mean they don't work? You double click the installers and nothing comes up? If so you might have the Windows Installer Service disabled. You can check this by going to Start>Control Panel>Administrative Tools>Services. If that's not the problem try installing the latest Divx 5.
"What do you mean they don't work?"
Sorry, I mean they don't show up in virtualdub or DVD2AVI, as selectable compression codec's (i.e. Virtualdub->Video->compression). They used to before the fresh winxp install...
As for Start>Control Panel>Administrative Tools>Services, I didn't intentionally disable this, how can I be sure it isn't disabled... there is a lot of files under extended and stardard, although I can't spot divx anywhere...
Thanks,
rhuala
Problems Installing RipBot
By Dan_Joyner in forum Blu-ray RippingReplies: 8Last Post: 16th Apr 2013, 07:20 -
problems installing bd rebuilder
By davechubb in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jan 2012, 04:09 -
DivX playback problems on Philips DVP 3040 (since installing WinXP SP2)
By mikester2 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 22nd Nov 2007, 13:54 -
Need quick help installing divx 3.11
By majax79 in forum Software PlayingReplies: 4Last Post: 31st Oct 2007, 09:54 -
problems installing flash player
By stretchweider in forum MacReplies: 3Last Post: 29th Aug 2007, 10:51
