I have a wireless gamepad (pelican accessories) that I am attempting to use with my XP computer. I have the "super dual box" USB connector, and I have the wireless PSX adapter plugged into player-1 slot. I cannot get the PC to recognise the gamepad. I know the gamepad works perfect connected to the PSX-one. I have gone into XP's Control Settings/ Game Controllers and attempted to setup the gamepad, but it says "not connected" and I am unable to set it.
I am able to get another gamepad - a Cosmos wireless - to work so it is something particluar to the pelican
any help or assistance will be appreciated.
Patrick
go to device manager and see if it shows up there.
Try it in another USB port.
Try it in another player port #2 maybe.
Go to the manufacturer site and see if there's a driveer/patch you need for XP.
What's the best Pad for PC
By themaster1 in forum ComputerReplies: 3Last Post: 15th Mar 2010, 16:43 -
How do wireless signals work?
By videohalp in forum ComputerReplies: 3Last Post: 6th May 2009, 20:15 -
HAVA Wireless HD - How does it work?
By RoganSarine in forum Capturing and VCRReplies: 0Last Post: 31st Dec 2007, 02:11 -
how to limit speed of users on wireless network (router-lan-wireless)
By deejay.2001 in forum ComputerReplies: 5Last Post: 3rd Nov 2007, 00:56 -
USB Wireless lan stronger than Internal wireless?
By Super Warrior in forum ComputerReplies: 11Last Post: 7th Aug 2007, 00:26
