i encode the movie file with tmpgenc. Then i burn it with nero 6. But when i play it in my dvd player there is no sound. Is there some kind of settings that i kind to change.
Not a lot of detail to go off.
Does it play on your PC ok?
You did play the mpeg after encoding to see if it was OK ? Before you used Nero. -
hmm not alot to go on here, but ill guess that ur "movie file" was an avi divx or xvid and it had mp3 or ac3 audio, what u do is b4 encoding with tmpgenc u extact the audio and save as a wav file, using virtual dub, load the video and on the file menu select save wav and use this audio in tmpgenc. if u still have the mpeg file just multiplex this wav file into the mpeg save u re-encoding
like andyp1 said, have you tried it in your puter?
i know my player is the main prob for me on this one. the optical connection doesnt read. i have to switch my reciever to analog and use component connections.
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 21:03 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
What are the downsides to having both onboard sound and Sound Card enabled?
By c627627 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 14:44 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01
