How can I convert an Mpeg file of 320 x 240 that has a 23.976 to 29.970 or vice-versa? Is it possible? If it is can we do it without having synch problem?
Results 1 to 15 of 15
23.976fps is converted to 29.97fps through a process called a telecine, and the reverse is done through a process called an Inverse telecine.
TMPGenc can perform a telecine by setting the output framerate to 29.97fps and enabling the 3:2 pulldown filter on the advanced tab. There is almost no reason to ever do this. VCDs, SVCDs, and DVDs support an internal framerate of 23.976fps. This means you encode it at 23.976fps (much higher quality-do a forum search on ntscfilm) and it is played back at 29.97fps. This is how the vast majority of commercial DVDs are made.
TMPGenc can perform an inverse telecine by setting output to 23.976fps and enabling the Inverse telecine filter on the advanced tab.
Audio sync is a non-issue when doing a proper telecine. A telecine creates new frames from existing fields, so the runtime doesn't change there are just more frames every second. -
Standard DVD does not support 23.976 fps. You have to use 3:2 pulldown, and its supported only with MPeg2.
You have to chose 352x240 to keep the aspect ratio. But if you insist on changing it, then click Load - extra - unlock.mcf. Then something like arrange settings - center. VCD does support 23.976 frame rate, so no need to change it in your case.
He can arrange it to center setting to keep the video at 320x240, and encode at 352x240, thats what i wrote, or tried to write
. But, then he lose aspect ratio.
Originally Posted by thor300
Originally Posted by adam
I found that in my experience, Main Concept is the best at framerate conversions such as PAL 25 FPS to NTSC 29.97 FPS VCD conversions.
It seems to be less jumpy and keeps the audio in synch very well. I'm pretty sure it could be the same for your conversion. -
jtommyj, find it hard to believe that framerate conversion is better than 3:2 pulldown/inverse telecine. When going from Pal to Ntsc and vice-versa its needed, sure, but pulldown/inverse telecine is lossless. I think you have a point anyway about the jumpiness, so maybe its worth a try. And thanx for the advice about Mainconcept, i havent tried that as i only have trial version. Am very satisfied with AviSynths ConvertFPS() in blend mode so far, but maybe i'll give it a shot with Mainconcept next time.
Not saying it is better than 3:2 pulldown, just another option.
For me it is simpler to just put a PAL 25 FPS in Main Concept and let it do the work to 29.97 NTSC VCD, which is different from 23.97 to 29.97. I also adjust the audio at that point to 48K so I can get around 6.5 hours of VCD's on a single DVD using TMPGEnc DVD Author, or I let DVD Author convert the audio for me.
Tom
dvd to vhs recorders and vice versa
By videohell in forum DVD & Blu-ray RecordersReplies: 2Last Post: 25th Nov 2011, 06:02 -
720p video on a 1080p TV, and vice versa?
By sldvd in forum Newbie / General discussionsReplies: 15Last Post: 16th Jun 2011, 21:21 -
How to convert 5.1 to 2.0 AC3 and vice versa
By lapetite_66 in forum AudioReplies: 5Last Post: 8th Mar 2010, 19:30 -
How to convert fullscreen to widescreen and vice versa?
By coxanhvn in forum Newbie / General discussionsReplies: 7Last Post: 16th Jul 2009, 23:01 -
change avi from 16:9 to 4:3 and vice versa
By slowjoe in forum EditingReplies: 9Last Post: 6th Jun 2007, 07:11
