I ran an .avi movie through ffmpegX 0.0.9e using the hi-bitrate DVD preset. The .avi movie is 1 hr 26 min long. The .mpg and .mpg.DVD output movies were only 25 min long. I ran the .avi through DivX Doctor II and the output .mov was 1 hr and 26 min long. When I input the .mov through ffmpegX, the output files were agin only 25 min long.
Any suggestions? Here is the process information. Thank you.
Mazjazz
Encoding started on Sat Apr 24 09:16:49 PDT 2004
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
++ WARN: [yuvscaler] Could not infer norm (PAL/SECAM or NTSC) from input data (frame size=720x480, frame rate=24000:1001 fps)!!
INFO: [yuvscaler] input: frame size: 720x480 pixels (518400 bytes)
INFO: [yuvscaler] input: frame rate: 24000/1001 fps (~23.976024)
INFO: [yuvscaler] input: interlace: none/progressive
INFO: [yuvscaler] input: sample aspect ratio: 1:1
INFO: [yuvscaler] from 720x480, take 720x480+0+0, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] scale to 720x480, 720x480 being displayed, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] Scaling uses the RESAMPLE algorithm,
INFO: [yuvscaler] without line switching
INFO: [yuvscaler] without time forwarding
INFO: [yuvscaler] Without luminance correction
INFO: [yuvscaler] Without chrominance correction
INFO: [yuvscaler] frame rate: 23.976 fps
INFO: [yuvscaler] Scaling ratio for width is 1 to 1
INFO: [yuvscaler] and is 1 to 1 for height
INFO: [yuvscaler] Specific downscaling routing number 4
INFO: [yuvscaler] output: frame size: 720x480 pixels (518400 bytes)
INFO: [yuvscaler] output: frame rate: 24000/1001 fps (~23.976024)
INFO: [yuvscaler] output: interlace: none/progressive
INFO: [yuvscaler] output: sample aspect ratio: 1:1
INFO: [mpeg2enc] Selecting DVD output profile
INFO: [mpeg2enc] Assuming norm NTSC
++ WARN: [mpeg2enc] 3:2 movie pulldown with frame rate set to decode rate not display rate
++ WARN: [mpeg2enc] 3:2 Setting frame rate code to display rate = 4 (29.970 fps)
INFO: [mpeg2enc] Encoding MPEG-2 video to /Volumes/Backup HD/SCARY_MOVIE.m2v
INFO: [mpeg2enc] Horizontal size: 720 pel
INFO: [mpeg2enc] Vertical size: 480 pel
INFO: [mpeg2enc] Aspect ratio code: 2 = 4:3 display
INFO: [mpeg2enc] Frame rate code: 4 = 30000.0/1001.0 (NTSC VIDEO)
INFO: [mpeg2enc] Bitrate: 4000 KBit/s
INFO: [mpeg2enc] Quality factor: 3 (Quantisation = 3) (1=best, 31=worst)
INFO: [mpeg2enc] Field order for input: none/progressive
INFO: [mpeg2enc] New Sequence every 9999 Mbytes
INFO: [mpeg2enc] Assuming non-video stream of 246 Kbps
INFO: [mpeg2enc] Search radius: 16
INFO: [mpeg2enc] GOP SIZE RANGE 9 TO 15
INFO: [mpeg2enc] Setting colour/gamma parameters to "NTSC"
INFO: [mpeg2enc] Progressive format frames = 1
INFO: [mpeg2enc] 3:2 Pulldown selected frame decode rate = 23.976 fps
INFO: [mpeg2enc] Using default unmodified quantization matrices
INFO: [mpeg2enc] Buffering 39 frames
INFO: [mpeg2enc] SETTING AltiVec for QUANTIZER!
INFO: [mpeg2enc] SETTING AltiVec for MOTION!
INFO: [mpeg2enc] SETTING AltiVec for TRANSFORM!
INFO: [mpeg2enc] SETTING AltiVec for PREDICTION!
INFO: [yuvscaler] End of stream!
INFO: [yuvscaler] Normal exit: end of stream with frame number 36336!
INFO: [mpeg2enc] Guesstimated final muxed size = 739473118
INFO: Opened WAV file, freq = 44100 Hz, channels = 2, bits = 16
INFO: format = 0x1, audio length = 267319208 bytes
INFO: slots/frame = 672
INFO: frac SpF=0.000, tot bitrate=224 kbps, s freq=48.0 kHz
INFO: System is big endian
INFO: Avg slots/frame = inf; b/smp = inf; br = inf kbps
INFO: Encoding with psychoacoustic model 2 is finished
INFO: The MPEG encoded output file name is "/Volumes/Backup HD/SCARY_MOVIE.mp2"
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [mplex] File /Volumes/Backup HD/SCARY_MOVIE.m2v looks like an MPEG Video stream.
INFO: [mplex] File /Volumes/Backup HD/SCARY_MOVIE.mp2 looks like an MPEG Audio stream.
INFO: [mplex] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [mplex] Found 1 audio streams and 1 video streams
INFO: [mplex] Selecting dvdauthor DVD output profile
INFO: [mplex] Multiplexing video program stream!
INFO: [mplex] Scanning for header info: Video stream e0 (/Volumes/Backup HD/SCARY_MOVIE.m2v)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 720
INFO: [mplex] Frame height : 480
INFO: [mplex] Aspect ratio : 4:3 display
INFO: [mplex] Picture rate : 29.970 frames/sec
INFO: [mplex] Bit rate : 4000000 bits/sec
INFO: [mplex] Vbv buffer size : 229376 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: Audio stream c0 (/Volumes/Backup HD/SCARY_MOVIE.mp2)
INFO: [mplex] MPEG AUDIO STREAM: c0
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 2
INFO: [mplex] CRC checksums : no
INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: [mplex] Frequency : 48000 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 0 copy
INFO: [mplex] Emphasis : 0 none
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 4294048
INFO: [mplex] target data-rate specified : 10080000
INFO: [mplex] Setting specified specified data rate: 10080000
INFO: [mplex] Run-in Sectors = 89 Video delay = 13019 Audio delay = 14520
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
INFO: [mplex] Scanned to end AU 36335
INFO: [mplex] STREAM e0 completed @ frame 36335.
INFO: [mplex] STREAM c0 completed @ frame 63141.
INFO: [mplex] Multiplex completion at SCR=136388461.
INFO: [mplex] Video e0: buf= 145001 frame=036335 sector=00343414
INFO: [mplex] Audio c0: buf= 736 frame=063141 sector=00021006
INFO: [mplex] VIDEO_STATISTICS: e0
INFO: [mplex] Video Stream length: 692871063 bytes
INFO: [mplex] Sequence headers: 2452
INFO: [mplex] Sequence ends : 1
INFO: [mplex] No. Pictures : 36335
INFO: [mplex] No. Groups : 2452
INFO: [mplex] No. I Frames : 2452 avg. size 28343 bytes
INFO: [mplex] No. P Frames : 9693 avg. size 22505 bytes
INFO: [mplex] No. B Frames : 24191 avg. size 16751 bytes
INFO: [mplex] Average bit-rate : 3657200 bits/sec
INFO: [mplex] Peak bit-rate : 3918400 bits/sec
INFO: [mplex] BUFFERING min 15 Buf max 134306
INFO: [mplex] AUDIO_STATISTICS: c0
INFO: [mplex] Audio stream length 42431424 bytes.
INFO: [mplex] Syncwords : 63142
INFO: [mplex] Frames : 63142 padded
INFO: [mplex] Frames : 0 unpadded
INFO: [mplex] BUFFERING min 15 Buf max 683
INFO: [mplex] MUX STATUS: no under-runs detected.
INFO: dvdauthor creating VTS
STAT: Picking VTS 01
STAT: Processing /Volumes/Backup HD/SCARY_MOVIE.mpg...
STAT: VOBU 16 at 2MB, 1 PGCS, 0:00:09
STAT: VOBU 32 at 7MB, 1 PGCS, 0:00:19
STAT: VOBU 48 at 11MB, 1 PGCS, 0:00:29
STAT: VOBU 64 at 16MB, 1 PGCS, 0:00:39
STAT: VOBU 80 at 21MB, 1 PGCS, 0:00:49
STAT: VOBU 96 at 25MB, 1 PGCS, 0:00:59
STAT: VOBU 112 at 30MB, 1 PGCS, 0:01:09
STAT: VOBU 128 at 34MB, 1 PGCS, 0:01:19
STAT: VOBU 144 at 39MB, 1 PGCS, 0:01:28
STAT: VOBU 160 at 43MB, 1 PGCS, 0:01:38
STAT: VOBU 176 at 47MB, 1 PGCS, 0:01:48
STAT: VOBU 192 at 52MB, 1 PGCS, 0:01:58
STAT: VOBU 208 at 56MB, 1 PGCS, 0:02:08
STAT: VOBU 224 at 61MB, 1 PGCS, 0:02:18
STAT: VOBU 240 at 65MB, 1 PGCS, 0:02:27
STAT: VOBU 256 at 69MB, 1 PGCS, 0:02:37
STAT: VOBU 272 at 74MB, 1 PGCS, 0:02:46
STAT: VOBU 288 at 78MB, 1 PGCS, 0:02:56
STAT: VOBU 304 at 83MB, 1 PGCS, 0:03:06
STAT: VOBU 320 at 88MB, 1 PGCS, 0:03:16
STAT: VOBU 336 at 93MB, 1 PGCS, 0:03:26
STAT: VOBU 352 at 98MB, 1 PGCS, 0:03:36
STAT: VOBU 368 at 103MB, 1 PGCS, 0:03:46
STAT: VOBU 384 at 107MB, 1 PGCS, 0:03:56
STAT: VOBU 400 at 112MB, 1 PGCS, 0:04:06
STAT: VOBU 416 at 116MB, 1 PGCS, 0:04:15
STAT: VOBU 432 at 121MB, 1 PGCS, 0:04:25
STAT: VOBU 448 at 125MB, 1 PGCS, 0:04:35
STAT: VOBU 464 at 128MB, 1 PGCS, 0:04:44
STAT: VOBU 480 at 133MB, 1 PGCS, 0:04:54
STAT: VOBU 496 at 138MB, 1 PGCS, 0:05:04
STAT: VOBU 512 at 142MB, 1 PGCS, 0:05:14
STAT: VOBU 528 at 146MB, 1 PGCS, 0:05:24
STAT: VOBU 544 at 151MB, 1 PGCS, 0:05:34
STAT: VOBU 560 at 155MB, 1 PGCS, 0:05:44
STAT: VOBU 576 at 159MB, 1 PGCS, 0:05:54
STAT: VOBU 592 at 163MB, 1 PGCS, 0:06:04
STAT: VOBU 608 at 167MB, 1 PGCS, 0:06:13
STAT: VOBU 624 at 172MB, 1 PGCS, 0:06:23
STAT: VOBU 640 at 176MB, 1 PGCS, 0:06:33
STAT: VOBU 656 at 181MB, 1 PGCS, 0:06:43
STAT: VOBU 672 at 185MB, 1 PGCS, 0:06:53
STAT: VOBU 688 at 189MB, 1 PGCS, 0:07:03
STAT: VOBU 704 at 194MB, 1 PGCS, 0:07:13
STAT: VOBU 720 at 199MB, 1 PGCS, 0:07:23
STAT: VOBU 736 at 204MB, 1 PGCS, 0:07:33
STAT: VOBU 752 at 208MB, 1 PGCS, 0:07:43
STAT: VOBU 768 at 213MB, 1 PGCS, 0:07:52
STAT: VOBU 784 at 217MB, 1 PGCS, 0:08:02
STAT: VOBU 800 at 222MB, 1 PGCS, 0:08:11
STAT: VOBU 816 at 227MB, 1 PGCS, 0:08:21
STAT: VOBU 832 at 232MB, 1 PGCS, 0:08:31
STAT: VOBU 848 at 237MB, 1 PGCS, 0:08:41
STAT: VOBU 864 at 242MB, 1 PGCS, 0:08:51
STAT: VOBU 880 at 247MB, 1 PGCS, 0:09:01
STAT: VOBU 896 at 252MB, 1 PGCS, 0:09:11
STAT: VOBU 912 at 257MB, 1 PGCS, 0:09:21
STAT: VOBU 928 at 262MB, 1 PGCS, 0:09:30
STAT: VOBU 944 at 267MB, 1 PGCS, 0:09:40
STAT: VOBU 960 at 271MB, 1 PGCS, 0:09:49
STAT: VOBU 976 at 276MB, 1 PGCS, 0:09:59
STAT: VOBU 992 at 281MB, 1 PGCS, 0:10:09
STAT: VOBU 1008 at 286MB, 1 PGCS, 0:10:20
STAT: VOBU 1024 at 291MB, 1 PGCS, 0:10:30
STAT: VOBU 1040 at 296MB, 1 PGCS, 0:10:39
STAT: VOBU 1056 at 301MB, 1 PGCS, 0:10:49
STAT: VOBU 1072 at 307MB, 1 PGCS, 0:10:59
STAT: VOBU 1088 at 312MB, 1 PGCS, 0:11:09
STAT: VOBU 1104 at 316MB, 1 PGCS, 0:11:19
STAT: VOBU 1120 at 322MB, 1 PGCS, 0:11:29
STAT: VOBU 1136 at 327MB, 1 PGCS, 0:11:39
STAT: VOBU 1152 at 332MB, 1 PGCS, 0:11:50
STAT: VOBU 1168 at 337MB, 1 PGCS, 0:12:00
STAT: VOBU 1184 at 342MB, 1 PGCS, 0:12:10
STAT: VOBU 1200 at 347MB, 1 PGCS, 0:12:19
STAT: VOBU 1216 at 352MB, 1 PGCS, 0:12:29
STAT: VOBU 1232 at 357MB, 1 PGCS, 0:12:39
STAT: VOBU 1248 at 362MB, 1 PGCS, 0:12:49
STAT: VOBU 1264 at 367MB, 1 PGCS, 0:12:59
STAT: VOBU 1280 at 372MB, 1 PGCS, 0:13:09
STAT: VOBU 1296 at 377MB, 1 PGCS, 0:13:19
STAT: VOBU 1312 at 382MB, 1 PGCS, 0:13:29
STAT: VOBU 1328 at 387MB, 1 PGCS, 0:13:39
STAT: VOBU 1344 at 392MB, 1 PGCS, 0:13:49
STAT: VOBU 1360 at 396MB, 1 PGCS, 0:13:59
STAT: VOBU 1376 at 401MB, 1 PGCS, 0:14:09
STAT: VOBU 1392 at 406MB, 1 PGCS, 0:14:19
STAT: VOBU 1408 at 410MB, 1 PGCS, 0:14:29
STAT: VOBU 1424 at 415MB, 1 PGCS, 0:14:39
STAT: VOBU 1440 at 419MB, 1 PGCS, 0:14:49
STAT: VOBU 1456 at 424MB, 1 PGCS, 0:14:59
STAT: VOBU 1472 at 428MB, 1 PGCS, 0:15:09
STAT: VOBU 1488 at 433MB, 1 PGCS, 0:15:18
STAT: VOBU 1504 at 438MB, 1 PGCS, 0:15:28
STAT: VOBU 1520 at 442MB, 1 PGCS, 0:15:38
STAT: VOBU 1536 at 446MB, 1 PGCS, 0:15:48
STAT: VOBU 1552 at 451MB, 1 PGCS, 0:15:58
STAT: VOBU 1568 at 455MB, 1 PGCS, 0:16:07
STAT: VOBU 1584 at 459MB, 1 PGCS, 0:16:16
STAT: VOBU 1600 at 463MB, 1 PGCS, 0:16:26
STAT: VOBU 1616 at 468MB, 1 PGCS, 0:16:36
STAT: VOBU 1632 at 472MB, 1 PGCS, 0:16:46
STAT: VOBU 1648 at 477MB, 1 PGCS, 0:16:56
STAT: VOBU 1664 at 482MB, 1 PGCS, 0:17:06
STAT: VOBU 1680 at 486MB, 1 PGCS, 0:17:16
STAT: VOBU 1696 at 490MB, 1 PGCS, 0:17:25
STAT: VOBU 1712 at 495MB, 1 PGCS, 0:17:35
STAT: VOBU 1728 at 499MB, 1 PGCS, 0:17:45
STAT: VOBU 1744 at 504MB, 1 PGCS, 0:17:55
STAT: VOBU 1760 at 508MB, 1 PGCS, 0:18:05
STAT: VOBU 1776 at 513MB, 1 PGCS, 0:18:15
STAT: VOBU 1792 at 517MB, 1 PGCS, 0:18:25
STAT: VOBU 1808 at 522MB, 1 PGCS, 0:18:35
STAT: VOBU 1824 at 526MB, 1 PGCS, 0:18:45
STAT: VOBU 1840 at 530MB, 1 PGCS, 0:18:55
STAT: VOBU 1856 at 535MB, 1 PGCS, 0:19:05
STAT: VOBU 1872 at 540MB, 1 PGCS, 0:19:15
STAT: VOBU 1888 at 545MB, 1 PGCS, 0:19:25
STAT: VOBU 1904 at 550MB, 1 PGCS, 0:19:35
STAT: VOBU 1920 at 555MB, 1 PGCS, 0:19:45
STAT: VOBU 1936 at 559MB, 1 PGCS, 0:19:54
STAT: VOBU 1952 at 564MB, 1 PGCS, 0:20:04
STAT: VOBU 1968 at 569MB, 1 PGCS, 0:20:14
STAT: VOBU 1984 at 573MB, 1 PGCS, 0:20:24
STAT: VOBU 2000 at 578MB, 1 PGCS, 0:20:34
STAT: VOBU 2016 at 583MB, 1 PGCS, 0:20:44
STAT: VOBU 2032 at 588MB, 1 PGCS, 0:20:54
STAT: VOBU 2048 at 593MB, 1 PGCS, 0:21:03
STAT: VOBU 2064 at 597MB, 1 PGCS, 0:21:13
STAT: VOBU 2080 at 602MB, 1 PGCS, 0:21:23
STAT: VOBU 2096 at 607MB, 1 PGCS, 0:21:33
STAT: VOBU 2112 at 612MB, 1 PGCS, 0:21:43
STAT: VOBU 2128 at 618MB, 1 PGCS, 0:21:53
STAT: VOBU 2144 at 623MB, 1 PGCS, 0:22:03
STAT: VOBU 2160 at 628MB, 1 PGCS, 0:22:13
STAT: VOBU 2176 at 633MB, 1 PGCS, 0:22:23
STAT: VOBU 2192 at 638MB, 1 PGCS, 0:22:33
STAT: VOBU 2208 at 643MB, 1 PGCS, 0:22:43
STAT: VOBU 2224 at 648MB, 1 PGCS, 0:22:53
STAT: VOBU 2240 at 652MB, 1 PGCS, 0:23:03
STAT: VOBU 2256 at 657MB, 1 PGCS, 0:23:13
STAT: VOBU 2272 at 662MB, 1 PGCS, 0:23:23
STAT: VOBU 2288 at 667MB, 1 PGCS, 0:23:33
STAT: VOBU 2304 at 671MB, 1 PGCS, 0:23:43
STAT: VOBU 2320 at 676MB, 1 PGCS, 0:23:53
STAT: VOBU 2336 at 681MB, 1 PGCS, 0:24:03
STAT: VOBU 2352 at 686MB, 1 PGCS, 0:24:13
STAT: VOBU 2368 at 691MB, 1 PGCS, 0:24:23
STAT: VOBU 2384 at 696MB, 1 PGCS, 0:24:33
STAT: VOBU 2400 at 700MB, 1 PGCS, 0:24:43
STAT: VOBU 2416 at 705MB, 1 PGCS, 0:24:52
STAT: VOBU 2432 at 710MB, 1 PGCS, 0:25:02
STAT: VOBU 2448 at 715MB, 1 PGCS, 0:25:12
STAT: VOBU 2452 at 716MB, 1 PGCS, 0:25:15
INFO: Generating VTS with the following video attributes:
INFO: TV standard: ntsc
INFO: Aspect ratio: 4:3
INFO: Resolution: 720x480
INFO: Audio ch 0 format: mp2/2ch, 20bps
STAT: fixing VOBU at 2MB (17/2452, 0%)
STAT: fixing VOBU at 7MB (33/2452, 1%)
STAT: fixing VOBU at 11MB (49/2452, 1%)
STAT: fixing VOBU at 16MB (65/2452, 2%)
STAT: fixing VOBU at 21MB (81/2452, 3%)
STAT: fixing VOBU at 25MB (97/2452, 3%)
STAT: fixing VOBU at 30MB (113/2452, 4%)
STAT: fixing VOBU at 34MB (129/2452, 5%)
STAT: fixing VOBU at 39MB (145/2452, 5%)
STAT: fixing VOBU at 43MB (161/2452, 6%)
STAT: fixing VOBU at 47MB (177/2452, 7%)
STAT: fixing VOBU at 52MB (193/2452, 7%)
STAT: fixing VOBU at 56MB (209/2452, 8%)
STAT: fixing VOBU at 61MB (225/2452, 9%)
STAT: fixing VOBU at 65MB (241/2452, 9%)
STAT: fixing VOBU at 69MB (257/2452, 10%)
STAT: fixing VOBU at 74MB (273/2452, 11%)
STAT: fixing VOBU at 78MB (289/2452, 11%)
STAT: fixing VOBU at 83MB (305/2452, 12%)
STAT: fixing VOBU at 88MB (321/2452, 13%)
STAT: fixing VOBU at 93MB (337/2452, 13%)
STAT: fixing VOBU at 98MB (353/2452, 14%)
STAT: fixing VOBU at 103MB (369/2452, 15%)
STAT: fixing VOBU at 107MB (385/2452, 15%)
STAT: fixing VOBU at 112MB (401/2452, 16%)
STAT: fixing VOBU at 116MB (417/2452, 16%)
STAT: fixing VOBU at 121MB (433/2452, 17%)
STAT: fixing VOBU at 125MB (449/2452, 18%)
STAT: fixing VOBU at 128MB (465/2452, 18%)
STAT: fixing VOBU at 133MB (481/2452, 19%)
STAT: fixing VOBU at 138MB (497/2452, 20%)
STAT: fixing VOBU at 142MB (513/2452, 20%)
STAT: fixing VOBU at 146MB (529/2452, 21%)
STAT: fixing VOBU at 151MB (545/2452, 22%)
STAT: fixing VOBU at 155MB (561/2452, 22%)
STAT: fixing VOBU at 159MB (577/2452, 23%)
STAT: fixing VOBU at 163MB (593/2452, 24%)
STAT: fixing VOBU at 167MB (609/2452, 24%)
STAT: fixing VOBU at 172MB (625/2452, 25%)
STAT: fixing VOBU at 176MB (641/2452, 26%)
STAT: fixing VOBU at 181MB (657/2452, 26%)
STAT: fixing VOBU at 185MB (673/2452, 27%)
STAT: fixing VOBU at 189MB (689/2452, 28%)
STAT: fixing VOBU at 194MB (705/2452, 28%)
STAT: fixing VOBU at 199MB (721/2452, 29%)
STAT: fixing VOBU at 204MB (737/2452, 30%)
STAT: fixing VOBU at 208MB (753/2452, 30%)
STAT: fixing VOBU at 213MB (769/2452, 31%)
STAT: fixing VOBU at 217MB (785/2452, 31%)
STAT: fixing VOBU at 222MB (801/2452, 32%)
STAT: fixing VOBU at 227MB (817/2452, 33%)
STAT: fixing VOBU at 232MB (833/2452, 33%)
STAT: fixing VOBU at 237MB (849/2452, 34%)
STAT: fixing VOBU at 242MB (865/2452, 35%)
STAT: fixing VOBU at 247MB (881/2452, 35%)
STAT: fixing VOBU at 252MB (897/2452, 36%)
STAT: fixing VOBU at 257MB (913/2452, 37%)
STAT: fixing VOBU at 262MB (929/2452, 37%)
STAT: fixing VOBU at 267MB (945/2452, 38%)
STAT: fixing VOBU at 271MB (961/2452, 39%)
STAT: fixing VOBU at 276MB (977/2452, 39%)
STAT: fixing VOBU at 281MB (993/2452, 40%)
STAT: fixing VOBU at 286MB (1009/2452, 41%)
STAT: fixing VOBU at 291MB (1025/2452, 41%)
STAT: fixing VOBU at 296MB (1041/2452, 42%)
STAT: fixing VOBU at 301MB (1057/2452, 43%)
STAT: fixing VOBU at 307MB (1073/2452, 43%)
STAT: fixing VOBU at 312MB (1089/2452, 44%)
STAT: fixing VOBU at 316MB (1105/2452, 45%)
STAT: fixing VOBU at 322MB (1121/2452, 45%)
STAT: fixing VOBU at 327MB (1137/2452, 46%)
STAT: fixing VOBU at 332MB (1153/2452, 46%)
STAT: fixing VOBU at 337MB (1169/2452, 47%)
STAT: fixing VOBU at 342MB (1185/2452, 48%)
STAT: fixing VOBU at 347MB (1201/2452, 48%)
STAT: fixing VOBU at 352MB (1217/2452, 49%)
STAT: fixing VOBU at 357MB (1233/2452, 50%)
STAT: fixing VOBU at 362MB (1249/2452, 50%)
STAT: fixing VOBU at 367MB (1265/2452, 51%)
STAT: fixing VOBU at 372MB (1281/2452, 52%)
STAT: fixing VOBU at 377MB (1297/2452, 52%)
STAT: fixing VOBU at 382MB (1313/2452, 53%)
STAT: fixing VOBU at 387MB (1329/2452, 54%)
STAT: fixing VOBU at 392MB (1345/2452, 54%)
STAT: fixing VOBU at 396MB (1361/2452, 55%)
STAT: fixing VOBU at 401MB (1377/2452, 56%)
STAT: fixing VOBU at 406MB (1393/2452, 56%)
STAT: fixing VOBU at 410MB (1409/2452, 57%)
STAT: fixing VOBU at 415MB (1425/2452, 58%)
STAT: fixing VOBU at 419MB (1441/2452, 58%)
STAT: fixing VOBU at 424MB (1457/2452, 59%)
STAT: fixing VOBU at 428MB (1473/2452, 60%)
STAT: fixing VOBU at 433MB (1489/2452, 60%)
STAT: fixing VOBU at 438MB (1505/2452, 61%)
STAT: fixing VOBU at 442MB (1521/2452, 61%)
STAT: fixing VOBU at 446MB (1537/2452, 62%)
STAT: fixing VOBU at 451MB (1553/2452, 63%)
STAT: fixing VOBU at 455MB (1569/2452, 63%)
STAT: fixing VOBU at 459MB (1585/2452, 64%)
STAT: fixing VOBU at 463MB (1601/2452, 65%)
STAT: fixing VOBU at 468MB (1617/2452, 65%)
STAT: fixing VOBU at 472MB (1633/2452, 66%)
STAT: fixing VOBU at 477MB (1649/2452, 67%)
STAT: fixing VOBU at 482MB (1665/2452, 67%)
STAT: fixing VOBU at 486MB (1681/2452, 68%)
STAT: fixing VOBU at 490MB (1697/2452, 69%)
STAT: fixing VOBU at 495MB (1713/2452, 69%)
STAT: fixing VOBU at 499MB (1729/2452, 70%)
STAT: fixing VOBU at 504MB (1745/2452, 71%)
STAT: fixing VOBU at 508MB (1761/2452, 71%)
STAT: fixing VOBU at 513MB (1777/2452, 72%)
STAT: fixing VOBU at 517MB (1793/2452, 73%)
STAT: fixing VOBU at 522MB (1809/2452, 73%)
STAT: fixing VOBU at 526MB (1825/2452, 74%)
STAT: fixing VOBU at 530MB (1841/2452, 75%)
STAT: fixing VOBU at 535MB (1857/2452, 75%)
STAT: fixing VOBU at 540MB (1873/2452, 76%)
STAT: fixing VOBU at 545MB (1889/2452, 76%)
STAT: fixing VOBU at 550MB (1905/2452, 77%)
STAT: fixing VOBU at 555MB (1921/2452, 78%)
STAT: fixing VOBU at 559MB (1937/2452, 78%)
STAT: fixing VOBU at 564MB (1953/2452, 79%)
STAT: fixing VOBU at 569MB (1969/2452, 80%)
STAT: fixing VOBU at 573MB (1985/2452, 80%)
STAT: fixing VOBU at 578MB (2001/2452, 81%)
STAT: fixing VOBU at 583MB (2017/2452, 82%)
STAT: fixing VOBU at 588MB (2033/2452, 82%)
STAT: fixing VOBU at 593MB (2049/2452, 83%)
STAT: fixing VOBU at 597MB (2065/2452, 84%)
STAT: fixing VOBU at 602MB (2081/2452, 84%)
STAT: fixing VOBU at 607MB (2097/2452, 85%)
STAT: fixing VOBU at 612MB (2113/2452, 86%)
STAT: fixing VOBU at 618MB (2129/2452, 86%)
STAT: fixing VOBU at 623MB (2145/2452, 87%)
STAT: fixing VOBU at 628MB (2161/2452, 88%)
STAT: fixing VOBU at 633MB (2177/2452, 88%)
STAT: fixing VOBU at 638MB (2193/2452, 89%)
STAT: fixing VOBU at 643MB (2209/2452, 90%)
STAT: fixing VOBU at 648MB (2225/2452, 90%)
STAT: fixing VOBU at 652MB (2241/2452, 91%)
STAT: fixing VOBU at 657MB (2257/2452, 92%)
STAT: fixing VOBU at 662MB (2273/2452, 92%)
STAT: fixing VOBU at 667MB (2289/2452, 93%)
STAT: fixing VOBU at 671MB (2305/2452, 93%)
STAT: fixing VOBU at 676MB (2321/2452, 94%)
STAT: fixing VOBU at 681MB (2337/2452, 95%)
STAT: fixing VOBU at 686MB (2353/2452, 95%)
STAT: fixing VOBU at 691MB (2369/2452, 96%)
STAT: fixing VOBU at 696MB (2385/2452, 97%)
STAT: fixing VOBU at 700MB (2401/2452, 97%)
STAT: fixing VOBU at 705MB (2417/2452, 98%)
STAT: fixing VOBU at 710MB (2433/2452, 99%)
STAT: fixing VOBU at 715MB (2449/2452, 99%)
STAT: fixed 2452 VOBUS
INFO: dvdauthor creating table of contents
scanning /Volumes/Backup HD/SCARY_MOVIE.mpg.DVD/VIDEO_TS/VTS_01_0.IFO
/Applications/ffmpegX.app//Contents/Resources/mkisofs: No such file or directory. Invalid node - /Volumes/Backup\ HD/SCARY_MOVIE.mpg.DVD
Hi again Mazz
Hopefully Major will have a better answer to your question!
But in the meantime - how large was your original avi and how large is the mpeg2 output file? And - I hesitate to ask this but - did you run out of disk space again?
Also have you tried playing the mpeg2 in vlc or something. What happens after 26 mins? Sometimes the reported duration of video is incorrect (especially the durations reported by the Finder if you have 'Show Icon Info' checked in Finder's 'Show View Options').
Hi again thoughton, thanks for remembering me.
The orginal avi is 708.5 MB. The mpg out file is 716.5 MB. I didn't run out of disk space, I think I learn my lesson on that. On VLC, the mpg file is 15 min long. When I double click it, QuickTime lauches and the end of the mpg file shows 00:25:15. There nothing passed the 25:15 min. QuickTime goes back to the beginning.
Mazjazz
rip dvd using ripbot264 does not load complete movie
By magmo in forum DVD RippingReplies: 7Last Post: 11th Jun 2012, 20:51 -
I can't rip a complete movie.
By Marccc in forum DVD RippingReplies: 1Last Post: 17th May 2010, 07:39 -
DVD to complete MPEG2
By neftv in forum Video ConversionReplies: 7Last Post: 22nd Mar 2008, 13:40 -
Movie in a .rar file 99.9% complete, is there a way to extract it?
By dexter30 in forum Newbie / General discussionsReplies: 13Last Post: 10th Feb 2008, 08:55 -
AVI to DVD - not complete movie!
By stuie_e in forum Newbie / General discussionsReplies: 1Last Post: 20th May 2007, 14:52
