OK, this should be do-able. I have a DVD RAM disk burned on a Panasonic E-50. I want to transfer this to a DVD-R on my computer. Whenever I go to make an image (I tried both DvdDecrypter and Nero and two different discs with various programs) it reads fine until the last 10% or so of the disc and then the read slows down to a crawl. I am able to copy the files (there are only 3) to my hard drive and burn them with Nero but I need to know what format to burn them so they are readable with a stand alone DVD player. I was able to make this work once with DvdDecrypter using a short few minute burn but whenever I go to a large file on the RAM disc is just won’t read to make an ISO file.
I need help either getting an ISO from a RAM disc OR burning the Panasonic DVD files from my RAM disc with Nero to a readable DVD video.
Thanks in advance.
Just to be perfectly clear, I do not want to do any editing. I just want a copy of the DVD-Ram. All my players will play the DVD-Ram just as it is and they will play the small copy I made with DVDDecrypter so I assume if I can get the right format I should be able to use Nero unless there is something done in creating an ISO file that I cannot replicate.
Still a few bugs in the system...
Copy the VRO(s) to your hard drive, edit/re-author/ burn with TMPGEnc DVD Author.
I don't think you can do a straight image copy from ram to -R, and it wouldn't play on most DVD players if you could. Re-authoring is the only way."Art is making something out of nothing and selling it." - Frank Zappa -
Originally Posted by ZippyP.
I am trying to avoid buying more software and I wonder why the smaller file would copy into ISO and play just fine while the larger one will not.
ADDED: I tried your suggestion and of course it did work. I think I will just put up with the Panasonic menus and leave the edits in. The additional 2 hours of processing time is just too hard on the equipment; both mine and the computers. Plus the E-50 adds chapter points every 5 minutes that are handy.Still a few bugs in the system...
copying a DVD with Nero
By Videoguy1 in forum Authoring (DVD)Replies: 6Last Post: 10th Oct 2011, 08:14 -
Problems copying .VRO files from DVD-RAM -- SOLVED!
By usually_quiet in forum DVD RippingReplies: 14Last Post: 2nd Jun 2011, 16:30 -
DVD copying with Nero - demands DVD/RW disc and still doesn't work.
By gorelle in forum Newbie / General discussionsReplies: 4Last Post: 5th Apr 2008, 04:44 -
Does Nero decrypt when copying DVD?
By shun in forum DVD RippingReplies: 2Last Post: 2nd Sep 2007, 20:09 -
Can't copy a (ISO) DVD I just burned in Nero
By perceptionist in forum Newbie / General discussionsReplies: 5Last Post: 5th Jun 2007, 21:49
